1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: getAddress method behaviour
To: "Heesterman, Peter J" <[email protected]>
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Tue, 23 Dec 2014 14:42:09 +0000
Are the right asyn address numbers being passed into device support, like:
record(longin, "blah")
   field(DTYP, "asynInt32")
   field(INP,  "@asyn(turbo,addr,timeout)blah_param")
where addr=0..4?
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
On Dec 23, 2014, at 5:04 AM, "Heesterman, Peter J" <[email protected]> wrote:
> Hi Mark,
> I attach 2 reports.
> (FYI, I am working with 2 separate IOC apps.
> The second being a TCP server that is intended to simulate the I/O behaviour of the pump(s).
> I don't currently have access to the 'real' hardware.)
> Cheers,
> Peter.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 23 December 2014 02:43
> To: Heesterman, Peter J
> Cc: EPICS Tech-Talk ([email protected])
> Subject: RE: getAddress method behaviour
> What does the following show?
> asynReport 10 YOUR_PORT_NAME
> Mark
> From: Heesterman, Peter J [[email protected]]
> Sent: Monday, December 22, 2014 9:23 AM
> To: Mark Rivers
> Hi Mark,
> I am passing the former.
> BTW, I have configured the IOC with ASYN_MULTIDEVICE, and maxAddr 5.
> Cheers,
> Peter.
> Sent: 22 December 2014 15:21
> I suspect you are passing the wrong pasynUser to getAddres(). Are you passing the one that was passed into writeInt32 or the pasynUserSelf? You should pass the former.
> Mark
> Sent from my iPhone
> On Dec 22, 2014, at 9:12 AM, Heesterman, Peter J <[email protected]<mailto:[email protected]>> wrote:
> Hi Mark,
> I’m sorry to trouble you.
> In my application I am seeking to connect multiple devices (i.e. multiple pumps, in this case).
> So, for example, I have record names like:
> TURBOSIM:5:WarningTemperature (5 being the last of 5 devices connected).
> I had expected asynPortDriver::getAddress to emit the index of the device being addressed (0..4, in this example).
> But the only address value I can detect being emitted from the method, is 0 (e.g. when called within readInt32).
> I believe it is being invoked with asynUser(s) that are correctly associated with a specific device.
> What could I be missing?
> Many thanks,
> Peter.
> <TURBOSIMReport.txt><TURBOReport.txt>
RE: getAddress method behaviour Heesterman, Peter J
Re: getAddress method behaviour Mark Rivers
RE: getAddress method behaviour Mark Rivers
Prev: Bug in 3.14 and 3.15: "*.FLNK is a Channel Access Link ..." Dirk Zimoch
Next: RE: getAddress method behaviour Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: getAddress method behaviour Heesterman, Peter J
Next: RE: getAddress method behaviour Heesterman, Peter J
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
