1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fwd: Problem in database using Asyn Driver
To: [email protected]
Date: Mon, 29 Dec 2014 19:43:10 +0500
Dear All
I want to send and receive data at port. I am successfully sending the data and verified it but I can't receive the data from the port. Please check the problem and suggest me how to correct it. I have attached my database file. My st.cmd file is:
#!../../bin/linux-x86/serialTest
## You may have to change serialTest to something else
## everywhere it appears in this file
< envPaths
cd ${TOP}
dbLoadDatabase "dbd/serialTest.dbd"
serialTest_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("L0","localhost:5011",0,0,0)
## Load record instances
#dbLoadRecords("db/xxx.db","user=tasaddaqHost")
dbLoadRecords("db/asynRecord.db","P=a:,R=b,PORT=L0, ADDR=0,TIMEOUT=1,IMAX=100,OMAX=100")
dbLoadRecords("db/serialTest.db","PORT=L0,R=b,ADDR=0,TIMEOUT=1")
#asynOctetSetInputEos("L0",0,"\n")
#asynOctetSetOutputEos("L0",0,"\n")
cd ${TOP}/iocBoot/${IOC}
iocInit
## Start any sequence programs
#seq sncxxx,"user=tasaddaqHost"
_________________________________________________________
and after running ioc the result is .....
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocserialTest")
epicsEnvSet("TOP","/home/tasaddaq/serialTest")
epicsEnvSet("EPICS_BASE","/home/tasaddaq/epics/base-3.14.12.3")
epicsEnvSet("ASYN","/home/tasaddaq/epics/asyn4-20")
cd /home/tasaddaq/serialTest
cd /home/tasaddaq/serialTest/iocBoot/iocserialTest
iocInit
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Jan 18 2013
epics> 2014/12/23 15:25:16.007 b:in devAsynOctet: readIt failed localhost:5011 timeout: Resource temporarily unavailable
epics>
best regards,
Tasaddaq
Attachment: serialTest.db
Description: Binary data
Re: Problem in database using Asyn Driver Mark Rivers
Prev: RE: getAddress method behaviour Heesterman, Peter J
Next: Re: Problem in database using Asyn Driver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Bug in 3.14 and 3.15: "*.FLNK is a Channel Access Link ..." Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
