1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Installing CaLab "V.1.2.1.5" on SL6.1
To: [email protected]
Date: Tue, 6 Jan 2015 11:24:20 -0500
Hi all,
I am new to LabView and CaLab.
I want to use CaLab with an already existing VI application in-order to access the variables via EPICS for alarming purposes. I have a central EPICS alarm handler where I monitor all other detector sub-systems. And I plan to use the same alarm handler for this purpose.
The current VI application runs on LabView8.2. Therefore I downloaded CaLab version 1.2.1.5 and tried installing it to get the following errors.
[root@ppdaq1 V.1.2.1.5]# g++ -fPIC -I /usr/local/epics/R3.14.12.4/include/ -I /usr/local/epics/R3.14.12.4/include/os/Linux/ -I /usr/local/natinst/LabVIEW-8.2/cintools -I /usr/local/CaLab/V.1.2.1.5/ -L /usr/local/epics/R3.14.12.4/lib/linux-x86/ -lca -lCom -shared caLab_dll.cpp -o calab.so
caLab_dll.cpp: In function ‘void postEvent(PV*)’:
caLab_dll.cpp:333: error: invalid conversion from ‘long unsigned int’ to ‘MagicCookie_t*’
caLab_dll.cpp:333: error:   initializing argument 1 of ‘MgErr PostLVUserEvent(MagicCookie_t*, void*)’
Have anybody seen this before? Any help is much appreciated.
Thank you.
- Chanaka.
Re: Installing CaLab "V.1.2.1.5" on SL6.1 Jani Hakala
Prev: Re: Stream device error when processing unsolicited commands Dirk Zimoch
Next: Problem building asyn R4-25 on Mac OSX Yosemite Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Possible bug in ca_clear_channel Benjamin Franksen
Next: Re: Installing CaLab "V.1.2.1.5" on SL6.1 Jani Hakala
