Hi:
On Jan 7, 2015, at 6:55 AM, Zunbeltz Izaola <[email protected]>
wrote:
> I got an java.lang.NullPointerException
> * 2015-01-07 12:39:23,296 FATAL [main] archive.engine.Application (?:?) -
> Unhandled Main Loop Error
> at org.csstudio.archive.engine.model.WriteThread.start(WriteThread.java:116)
> at org.csstudio.archive.engine.model.EngineModel.start(EngineModel.java:330)
> I can't find any odbious error in the configuration file.
> (ArchiveEngineConfig seems to run fine).
> Any idea what can be happening or where should I look?
> We are runing a modified archiver that stores in hypertable DB.
You should check line 116 of WriteThread.java to see what's null.
But to do that, you need to use your version of the sources, since you have a modified version of the source code.
In the current version of WriteThread, the start() method only spreads lines ~90 .. 100 (https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/plugins/org.csstudio.archive.engine/src/org/csstudio/archive/engine/model/WriteThread.java )
Kay
- Re: Can't start CSS RDB archiver zunbeltz
- Can't start CSS RDB archiver Zunbeltz Izaola
RE: Problem building asyn R4-25 on Mac OSX Yosemite Mark Rivers
send css browser data to web l123173
<2015>
2025
2026
<2015>
2025
2026
