running into following trouble:
make[5]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[6]: Entering directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
Creating dbd file simDetectorApp.dbd
perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd -I/home/h1/EPICS/support/asyn4-25/dbd -I/home/h1/EPICS/support/areaDetector/ADCore/dbd -I/home/h1/EPICS/support/calc-3-4/dbd -I/home/h1/EPICS/support/busy-1-6-1/dbd -I/home/h1/EPICS/support/sscan-2-10/dbd -I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
dbdExpand.pl: Leaving context "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'", found "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'" instead.
Braces must be closed in the same file they open in.
Context: file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'
while reading 'commonDriverSupport.dbd' to create 'simDetectorApp.dbd'
dbdExpand.pl: Exiting due to errors
make[6]: *** [../O.Common/simDetectorApp.dbd] Error 255
make[6]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src/O.linux-x86_64'
make[5]: *** [install.linux-x86_64] Error 2
make[5]: Leaving directory `/home/h1/EPICS/support/areaDetector/ADCore/iocs/simDetectorIOC/simDetectorApp/src'
make[4]: *** [src.install] Error 2
and don't know how to fix it ;-)
Where should I look? Which file may really cause the error?
Cheers,
Heinz
smime.p7s
Description: S/MIME cryptographic signature
- RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
RE: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Mark Rivers
<2015>
2025
2026
<2015>
2025
2026
