1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Accessing RPC result by CSS
To: [email protected]
Date: Mon, 12 Jan 2015 12:35:39 +0100
I'm an absolutly newbie.
I want to set up an 'EPICS envrionment' which uses CSS as operator interface
and where the process variables are provided by a java application. I read
several things about EPICS v3 and EPICS v4, took a look at CSS documentation
and now I have some question which I couldn't answer after reading the diffrent
help pages:
- Is it correct that by an remote procedure call using pvAcess is provided a
  EPICS v4 NT 'datastructure' which can build in the method which implements
  the RPCServer.
- How can I access the provided data by using CSS e.g. when I'm using a gauge
  object. I completed the 'PV Name' by 'pva://testservice/vname.value' but it
  didn't work. (In my case is 'testservice' the RPC service name, 'vname' the
  name of the NT structure and 'value' the NT_scalar which contais the 'provided
  data'.
Best regards
Prev: Re: What happened to "dbNameOfPV" in EPICS 3.15.1 : Need this for caPutLog Benjamin Franksen
Next: EPICS V4 on Windows freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
