1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: how to choose port of digitizer for IOC?
Date: Mon, 19 Jan 2015 10:56:26 -0800
I'm trying to make an IOC for a digitizer, the redpitaya. I've assigned it a static IP address and can successfully ssh to it, doing
However, there doesn't seem to be a specific port I should use in connecting to it - as least I see no mention of it in the documentation. I've tried using the "default" port numbers 5064,5065 in my st.cmd file, but both options give the
Can't connect to 10.95.101.75:5064: No route to host L0 -1 autoConnect could not connect
error message. I also get this warning
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 33122,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
but I've seen this with other IOCs for other devices, and those IOCs still work, so I'm assuming these warnings are not the fundamental issue.
Does anyone know what other ports I should try or should I instead try to reconfigure the redpitaya and assign it a port as well?
Ana Malagon
RE: how to choose port of digitizer for IOC? Mark Rivers
Prev: seg fault in sseq record when using AfterN option Pearson, Matthew R.
Next: RE: how to choose port of digitizer for IOC? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
