1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Waveform initialization
To: Henrique Almeida <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Mon, 19 Jan 2015 21:37:25 +0000
If you have autosave, you can tell it to write data from a .sav file to the waveform record.
Here's what the .sav file might look like for an 10-element array:
    myWaveformPV @array@ { "1" "2" "3" "4" "5" "6" "7" "8" "9" "10" }
Here's the command that tells autosave to use the .sav file, which I'll call "myData.sav".
Put it in your st.cmd file before the iocInit command
    set_pass1_restoreFile("myData.sav")
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Henrique Almeida [[email protected]]
Sent: Monday, January 19, 2015 1:29 PM
To: [email protected] Talk
Subject: Waveform initialization
 Hello, how can I initialize a waveform record with data ? I need to
initialize it before a sequencer starts (it is a temperature
controller PID program table).
RE: Waveform initialization Mooney, Tim M.
Waveform initialization Henrique Almeida
Prev: RE: new MVME5500, device "gei0" not found Mark Rivers
Next: RE: Waveform initialization Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Waveform initialization Henrique Almeida
