1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building edm on 64-bin debian
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 22 Jan 2015 16:29:06 +0100
Hi Ana,
What is your specific reason for building EPICS stuff from source on Debian?
There is a repository of production-quality EPICS packages for Debian.    http://epics.nsls2.bnl.gov/debian
Which basically means you can just install EPICS and a large set of drivers and extensions using the package manager. All the work you are going through already has been done.
If you find things missing or not working, it would be great if you contribute to the packaging effort - that way other Debian EPICS users can benefit directly from your work.    https://github.com/epicsdeb
Thanks a lot,
~Ralph
On 21/01/2015 01:25, Ana Malagon wrote:
Hi Mark,
Thanks; that did it - I checked for the location of libXt.so and found it in
/usr/lib/x86_64-linux-gnu
and the libXm had somehow gotten into the wrong directory so after moving that over and changing X11_LIB and MOTIF_LIB in CONFIG_SITE accordingly, it compiled!
Thanks very much as always for the quick replies :)
Ana
On Tue, Jan 20, 2015 at 4:05 PM, Mark Rivers <[email protected]> wrote:
Is there in fact a libXm.a or libXm.so file somewhere on your system?  If so, where is it?
In extensions/configure/CONFIG_SITE.linux-x86_64.linux-x86_64 what do X11_LIB and MOTIF_LIB point to?
From: [email protected] [mailto:[email protected]] On Behalf Of Ana Malagon
Sent: Tuesday, January 20, 2015 5:50 PM
To: [email protected]
Subject: building edm on 64-bin debian
I'm running into an error when building edm 1.12.98 with epics base 3.14.12.4 on a 64-bit machine with debian 7.5:
 *** No rule to make target `/usr/lib64/libXm.a', needed by `libcfcaa62e-8199-11d3-a77f-00104b8742df.so'.  Stop.
I've installed the packages I need using apt-get (libmotif-dev, libxmu-dev, libxt-dev), and I've tried changing the X11_LIB and MOTIF_LIB to /usr/lib64/x86_64-linux-gnu in the CONFIG_SITE.linux-x86_64.linux-x86_64 file in extensions/configure/os, as suggested in this posting, but I get the same error.
I don't seem to have a CONFIG_EXTENSIONS file anywhere so can't follow the steps from another post with the same error; anyone have any suggestions for what I might try next?
Ana
building edm on 64-bin debian Ana Malagon
RE: building edm on 64-bin debian Mark Rivers
Re: building edm on 64-bin debian Ana Malagon
Prev: EPICS driver for CAENels HV-Adaptos? nicoletta.de-maio
Next: Re: EPICS driver for CAENels HV-Adaptos? Faucett, John Allen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building edm on 64-bin debian Ana Malagon
Next: nsls2 debian package repo. update Michael Davidsaver
