1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer release 2.2.1
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Fri, 23 Jan 2015 08:29:59 +0000
On Tue, 2015-01-13 at 14:30 +0100, Benjamin Franksen wrote:
> This is the first proper (stable) release of version 2.2 of the
> sequencer. As mentioned in a previous post, the sequencer home page at
>   http://www-csr.bessy.de/control/SoftDist/sequencer/
> now documents version 2.2. There are links to the old (version 2.1) page
> in several places for easier navigation. The old page can also be
> directly reached via
Good morning sequencer users,
I've just tried to build seq-2.2.1
In test/validate pvAssignStress.st and pvAssignSubst.st both have the
same program name of pvAssignSubstTest which leads to:
pvAssignStress.o(.data+0x7c): multiple definition of `pvAssignSubstTest'
pvAssignSubst.o(.data+0x0): first defined here
pvAssignStress.o(.data+0xb4): multiple definition of
`pvar_func_pvAssignSubstTestRegistrar'
When running the tests I get this:
make -s runtests
snc_test.t .. Useless use of reference constructor in void context at
snc_test.t line 62.
Can't locate object method "subtest" via package "cast" (perhaps you
forgot to load "cast"?) at snc_test.t line 62.
# Looks like your test exited with 255 before it could output anything.
snc_test.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
Failed 23/23 subtests
Test Summary Report
snc_test.t (Wstat: 65280 Tests: 0 Failed: 0)
  Non-zero exit status: 255
  Parse errors: Bad plan.  You planned 23 tests but ran 0.
Files=1, Tests=0,  0 wallclock secs ( 0.02 usr  0.01 sys +  0.02 cusr
0.00 csys =  0.05 CPU)
Result: FAIL
Failed 1/1 test programs. 0/0 subtests failed.
I can fix the first problem but what about the tests?
Paul
Re: sequencer release 2.2.1 Benjamin Franksen
Prev: RE: Using asynDriver outside of an EPICS IOC Jimmy Johnson
Next: Re: sequencer release 2.2.1 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: sequencer release 2.2.1 Benjamin Franksen
