1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: how to control in sequence
To: <[email protected]>, <[email protected]>
Date: Tue, 27 Jan 2015 09:09:35 +0000
Hi YX Liang,
The easiest way to do this the first time is to use the sscan record - the documentation for this is here http://www.aps.anl.gov/bcda/synApps/sscan/sscanDoc.html.
In more detail you need to have a client that supports the Channel Access put_callback mechanism. This is the same as a normal channel access put, but only returns after all processing is finished (i.e. motor has finished moving or detector has finished exposing). If your detector is supported within areaDetector framework you have a bit more flexibility - if you use blocking callbacks to write the file the ca_put_callback will finish after the file is written, and if you use non-blocking callbacks ca_put_callback will finish at the end of the exposure, but before the file is written.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: 27 January 2015 08:18
To: tech-talk
Subject: how to control in sequence
Hi everyone,
    I could independently control two devices (motor and detector), I intend to make them action in some sequence(just like: motor move 2 setps then detector 2 seconds,and then and then).
    I don't know how to implement these and I get in touch with epics for a little time. Could you please offer me an example which I could study or some other help. Any advice would be helpful.
p.s.  I use CSS as the OPI.
Thank you
YX Liang
how to control in sequence 梁雅翔
Prev: caQtDM Mezger Anton Christian (PSI)
Next: Re: setting interpreter in EPICS Guy Jennings
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: how to control in sequence 梁雅翔
Next: caQtDM Mezger Anton Christian (PSI)
