1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to make standalone applications run from within EPICS shell
From: "Zelazny, Michael Stanley" <[email protected]>
To: Deeptarka Das/TVM/TCS <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Feb 2015 13:54:34 +0000
YES! The command is called "system".  In order to see it from your IOC shell, you'll need to add system.dbd to the Makefile in your application's src directory.
From: [email protected] [[email protected]] on behalf of Deeptarka Das/TVM/TCS [[email protected]]
Sent: Monday, February 9, 2015 4:44 AM
To: [email protected]
Subject: How to make standalone applications run from within EPICS shell
Hello,
If I create a standalone C program by writing necessary lines in the Makefile in the src folder of my EPICS application, I can see an executable created in the bin/$EPICS_HOST_ARCH folder. I can run this program from outside the IOC, but is there a way that I can run this from within the IOC? The way SNL codes are run using the seq command, is there a way to execute C codes from within the EPICS shell?
Thanks and Regards,
Deeptarka Das
Mailto: [email protected]<mailto:[email protected]>
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
How to make standalone applications run from within EPICS shell Deeptarka Das/TVM/TCS
Prev: How to make standalone applications run from within EPICS shell Deeptarka Das/TVM/TCS
Next: Re: Fetching return value from external program call in StreamDevice Christian Pauly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: using EPICS code with HTTP port Ana Malagon
