1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multiple overlays with NDPluginOverlay
To: David Michel <[email protected]>, EPICS mailing list <[email protected]>
Date: Wed, 11 Feb 2015 12:40:42 +0000
Hi David,
The example areaDetector IOCs all load the file commonPlugins.cmd.  That file loads NDOverlayN 8 times, so you can have up to 8 overlay items.  The first 2 are loaded with the following commands:
dbLoadRecords("$(ADCORE)/db/NDOverlayN.template","P=$(PREFIX),R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI1:MinX_RBV,YPOS=$(PREFIX)ROI1:MinY_RBV,XSIZE=$(PREFIX)ROI1:SizeX_RBV,YSIZE=
$(PREFIX)ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("$(ADCORE)/db/NDOverlayN.template","P=$(PREFIX),R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=$(PREFIX)ROI2:MinX_RBV,YPOS=$(PREFIX)ROI2:MinY_RBV,XSIZE=$(PREFIX)ROI2:SizeX_RBV,YSIZE=
$(PREFIX)ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
Note that the first command has ADDR=0, the second has ADDR=1.  That is what you are probably missing.
What camera are you running?  Are you loading commonPlugins.cmd from your startup script, as all of the example IOCs do?  If so then there are already 8 overlays.
From: [email protected] [[email protected]] on behalf of David Michel [[email protected]]
Sent: Wednesday, February 11, 2015 4:09 AM
To: EPICS mailing list
Subject: multiple overlays with NDPluginOverlay
Hi All,
I'm trying to get 2 overlays on my camera image but I'm confused with how to use NDPluginOverlay correctly. I've managed to get one overlay working properly with:
NDOverlayConfigure("$(PREFIX)OVER", $(QSIZE), 0, "$(PREFIX)ROI", 0, 1, 0, 0)
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDPluginBase.template","P=$(PREFIX),R=Over1:, PORT=$(PREFIX)OVER,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)ROI,NDARRAY_ADDR=0")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDOverlay.template","P=$(PREFIX),R=Over1:, PORT=$(PREFIX)OVER,ADDR=0,TIMEOUT=1")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDOverlayN.template","P=$(PREFIX),R=Over1:1:,NAME=Crosshair,SHAPE=0,O=Over1:,XPOS=400,YPOS=400,XSIZE=100,YSIZE=100,PORT=$(PREFIX)OVER,ADDR=0,TIMEOUT=1")
Now... I want to add a second overlay, my guess was that I could just load NDOverlayN.template again with R=Over1:2 and set maxOverlays=2 in the call to NDOverlayConfigure. This, however does not work, as both Over1:1 and Over1:2 seem to control the same single overlay. I must be missing something trivial here, any help greatly appreciated!
David
Re: multiple overlays with NDPluginOverlay David Michel
Prev: epics on ios Mezger Anton Christian (PSI)
Next: RE: can run multiple IOCs on single host? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: multiple overlays with NDPluginOverlay David Michel
Next: Re: multiple overlays with NDPluginOverlay David Michel
