1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host?
To: [email protected]
Date: Wed, 11 Feb 2015 10:46:59 -0500
On 02/11/2015 09:06 AM, Kasemir, Kay wrote:
> In addition, there seems to be some remaining difference between the C implementation of the channel access client library and the pure Java CAJ implementation. The only solution that always works: Somehow create a dummy network. Connect the host to a hub that's otherwise not connected to anything, just to get its ethernet light to come on, assign some IP address. Or enable the wireless network in 'peer' mode, again not really connected to anything, but you now have an IP and thus broadcast address that channel access can use on that host.
I spent some time recently trying to figure out how to deal with this
with Linux (for my laptop).
The difference between libca and CAJ which I found is that CAJ won't
accept 'localhost' in the address list even when explicitly given.
For Linux I looked at the various virtual NICs including tun/tap and
veth.  I found that none of them handle broadcasts.
The only "solution" I found was to force my un-connected ethernet
interface to be active.
Michael
Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? J. Lewis Muir
can run multiple IOCs on single host? JaeRyong Seo
Re: can run multiple IOCs on single host? Dirk Zimoch
Re: can run multiple IOCs on single host? Ralph Lange
Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? Kasemir, Kay
Prev: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? Kasemir, Kay
Next: Re: multiple overlays with NDPluginOverlay David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? J. Lewis Muir
