Hello to Everyone,
i'm trying to develop a control panel in CSS and i want to change
dynamically the macro substitution in a linking container widget through
a dedicated script. Reading the help documentation, i saw the Macros
Property can be changed with this code:
Javascript:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var macroInput = DataUtil.createMacrosInput(true);
macroInput.put("pv", PVUtil.getString(pvs[0]));
widget.setPropertyValue("macros", macroInput);
In runtime, i expect the container widget has a new macro called "pv"
with value coming from my variable set as pvs[0] (in my case i'm using a
stringout record), but the only macro available is an element called
"LCID" that changes at every page refresh (for example LCID=LCID_872 of
LCID=LCID_880).
Is there any configuration i'm forgetting to provide the correct set of
macro to my widget?
Thanks in advance for any help!
- Maurizio M.
asyn R4-26 available Mark Rivers
Possible to set EOS in asyn to match a character plus whatever character follows? Andrew Gomella
<2015>
2025
2026
<2015>
2025
2026
