Hi Mark,
We are facing a similar issue:
Our ASYN port driver for a DAQ board is modelling the board and its
channels as a multi device, with port=board and addr=channel.
During per-record-instance initialization, the port driver must call the
low level card driver with one configuration call per channel, using
board number, channel number, and range (record's EGUL, EGUF) as parameters.
What would be your approach for that?
Your intermediate record hack does not work nicely (in addition to being
somewhat ugly), as the parameter values would come in too late and
separately, and the addr=channel number is not contained in a field of
the "main" record.
The driver's connect() is only called once for the port, right?!
Couldn't that be complemented with a routine that is called once per
addr for multi devices, and gets the addr and maybe a pointer to the
parameter field of the link that it is being called for? (We'd be happy
to cram the necessary low level config params into the link config, and
have the driver pull it out.)
Alternatively, probably cleaner and more flexible, you could allow a
special info field for asyn driver configuration options to be added to
the record, and pass a a pointer to its string value when calling the
driver for each addr.
What do you think?
Thanks for your help,
~Ralph
On 02/02/2015 23:36, Mark Rivers wrote:
There is no direct communicaton possible between the NELM field of the waveform record and the asyn driver. However, it is easy to do using an intermediate longout record, for example:
record(longout,"$(P)$(R)NELM1") {
field(DOL, "$(P)$(R)Waveform1.NELM CP MS")
field(OMSL, "closed_loop")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))WAVEFORM_NELM1")
record(longout,"$(P)$(R)NELM2") {
field(DOL, "$(P)$(R)Waveform2.NELM CP MS")
field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))WAVEFORM_NELM2")
These longout records will process whenever the NELM fields change, including once at iocInit.
They will send the NELM field of the appropriate waveform record to you driver. You just need to treat the writes with 2 different pasynUser->reason values differently. If it is the one corresponding to WAVEFORM_NELM1 do one thing, and do something different if it is for WAVEFORM_NELM2.
- Re: Read record field in asynDriver Ralph Lange
- RE: Read record field in asynDriver Mark Rivers
- Read record field in asynDriver Vikram Bhagat
Re: Using the EPICS Build/Make system to build kernel modules for linux Michael Davidsaver
Re: Looking for Allen Bradley PLC5 Ethernet support Paul Sichta
<2015>
2025
2026
<2015>
2025
2026
