1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: sseq 2-2-1 issue/bug
To: Benjamin Franksen <[email protected]>, "Moore, Matthew D." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 20 Feb 2015 11:53:06 +0000
I don't see a "-lpv" in there anywhere.  Is there an snc_LIBS  variable?
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Benjamin Franksen [[email protected]]
Sent: Friday, February 20, 2015 5:35 AM
To: Moore, Matthew D.; [email protected]
Subject: Re: sseq 2-2-1 issue/bug
[cc-ing tech-talk as I am stupefied]
On Wednesday 11 February 2015 11:30:48 you wrote:
> It appears that seq 2-2-1 has an issue when building static. I have
> try it both on base 3.14.12.4 and 3.15.1. Everything is fine building
> with shared libraries, but for what I do I need to build static.
I have no idea why the static build gives undefined references. I do
have
seq_LIBS = pv Com
in the Makefile.
Is there anything else I have to do?
Cheers
Ben
> Here is the output. There is more before this, but I think this is
> enough to help you:
> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE
> -Dlinux -D_REENTRANT   -O3 -g   -Wall      -m64      -MMD -I.
> -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
> -I/local/DPbin/epics/epics_2015-03-31/base-3.14.12.4/include/os/Linux
> ../gen_code.c
> ../gen_ss_code.c
> ../gen_tables.c
> ../sym_table.c
> ../builtin.c
> ../type_check.c
> /usr/bin/g++ -o snc -Wl,-Bstatic
> -L/local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/seq-2-2-1/li
> b/linux-x86_64
> -L/local/DPbin/epics/epics_2015-03-31/base-3.14.12.4/lib/linux-x86_64
> -Wl,-rpath,/local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/se
> q-2-2-1/lib/linux-x86_64
> -Wl,-rpath,/local/DPbin/epics/epics_2015-03-31/base-3.14.12.4/lib/lin
> ux-x86_64 -m64               lexer.o snl.o main.o node.o var_types.o
> analysis.o gen_code.o gen_ss_code.o gen_tables.o sym_table.o
> builtin.o
> type_check.o    -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc
> -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lCom -lseq
> -Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
> /local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/seq-2-2-1/lib/
> linux-x86_64/libseq.a(seq_main.o): In function `init_sprog':
> /local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/seq-2-2-1/src/
> seq/O.linux-x86_64/../seq_main.c:228: undefined reference to
> `freeListInitPvt'
> linux-x86_64/libseq.a(seq_main.o): In function `init_chan':
> seq/O.linux-x86_64/../seq_main.c:431: undefined reference to
> `pv_sizes'
> `pv_value_sizes'
> `pv_sizes'
> seq/O.linux-x86_64/../seq_main.c:245: undefined reference to
> `epicsINF'
> linux-x86_64/libseq.a(seq_task.o): In function `ss_read_all_buffer':
> seq/O.linux-x86_64/../seq_task.c:183: undefined reference to
> `epicsINF'
> linux-x86_64/libseq.a(seq_task.o): In function `ss_entry':
> seq/O.linux-x86_64/../seq_task.c:303: undefined reference to
> `pvSysFlush'
> seq/O.linux-x86_64/../seq_task.c:310: undefined reference to
> `pvTimeGetCurrentDouble'
> seq/O.linux-x86_64/../seq_task.c:356: undefined reference to
> linux-x86_64/libseq.a(seq_task.o): In function `sequencer':
> seq/O.linux-x86_64/../seq_task.c:57: undefined reference to
> `pvSysAttach'
> linux-x86_64/libseq.a(seq_ca.o): In function `seq_camonitor':
> seq/O.linux-x86_64/../seq_ca.c:397: undefined reference to
> `pvVarMonitorOff'
> seq/O.linux-x86_64/../seq_ca.c:389: undefined reference to
> `pvVarMonitorOn'
> linux-x86_64/libseq.a(seq_ca.o): In function `seq_conn_handler':
> seq/O.linux-x86_64/../seq_ca.c:471: undefined reference to
> `pvVarGetCount'
> linux-x86_64/libseq.a(seq_ca.o): In function `seq_disconnect':
> seq/O.linux-x86_64/../seq_ca.c:357: undefined reference to
> `pvVarDestroy'
> linux-x86_64/libseq.a(seq_ca.o): In function `proc_db_events':
> seq/O.linux-x86_64/../seq_ca.c:285: undefined reference to
> `pv_value_offsets'
> seq/O.linux-x86_64/../seq_ca.c:289: undefined reference to
> `pv_stamp_offsets'
> seq/O.linux-x86_64/../seq_ca.c:290: undefined reference to
> `pv_status_offsets'
> seq/O.linux-x86_64/../seq_ca.c:291: undefined reference to
> `pv_severity_offsets'
> `pv_stamp_offsets'
> `pv_status_offsets'
> linux-x86_64/libseq.a(seq_ca.o): In function `seq_get_handler':
> seq/O.linux-x86_64/../seq_ca.c:153: undefined reference to
> `freeListFree'
> linux-x86_64/libseq.a(seq_ca.o): In function `seq_put_handler':
> seq/O.linux-x86_64/../seq_ca.c:172: undefined reference to
> `freeListFree'
> linux-x86_64/libseq.a(seq_ca.o): In function `putq_cp':
> seq/O.linux-x86_64/../seq_ca.c:234: undefined reference to
> `pv_value_sizes'
> seq/O.linux-x86_64/../seq_ca.c:234: undefined reference to `pv_sizes'
> linux-x86_64/libseq.a(seq_ca.o): In function `seq_connect':
> seq/O.linux-x86_64/../seq_ca.c:69: undefined reference to
> `pvVarCreate'
> seq/O.linux-x86_64/../seq_ca.c:85: undefined reference to `pvSysFlush'
> seq/O.linux-x86_64/../seq_ca.c:91: undefined reference to
> seq/O.linux-x86_64/../seq_ca.c:127: undefined reference to
> seq/O.linux-x86_64/../seq_ca.c:364: undefined reference to
> `pvSysFlush'
> linux-x86_64/libseq.a(seq_if.o): In function `seq_delay':
> seq/O.linux-x86_64/../seq_if.c:1263: undefined reference to
> linux-x86_64/libseq.a(seq_if.o): In function `getq_cp':
> seq/O.linux-x86_64/../seq_if.c:1186: undefined reference to
> `pv_status_offsets'
> seq/O.linux-x86_64/../seq_if.c:1187: undefined reference to
> seq/O.linux-x86_64/../seq_if.c:1188: undefined reference to
> `pv_stamp_offsets'
> seq/O.linux-x86_64/../seq_if.c:1191: undefined reference to
> `pv_value_offsets'
> `pv_status_offsets'
> linux-x86_64/libseq.a(seq_if.o): In function `putq_cp':
> seq/O.linux-x86_64/../seq_if.c:384: undefined reference to
> `pv_value_offsets'
> linux-x86_64/libseq.a(seq_if.o): In function `seq_pvAssign':
> seq/O.linux-x86_64/../seq_if.c:702: undefined reference to
> `pvVarDestroy'
> seq/O.linux-x86_64/../seq_if.c:759: undefined reference to
> `pvVarCreate'
> linux-x86_64/libseq.a(seq_if.o): In function `check_pending':
> seq/O.linux-x86_64/../seq_if.c:100: undefined reference to
> seq/O.linux-x86_64/../seq_if.c:107: undefined reference to
> linux-x86_64/libseq.a(seq_if.o): In function `seq_pvPutTmo':
> seq/O.linux-x86_64/../seq_if.c:494: undefined reference to
> `pvVarPutNoBlock'
> seq/O.linux-x86_64/../seq_if.c:510: undefined reference to
> `freeListMalloc'
> seq/O.linux-x86_64/../seq_if.c:517: undefined reference to
> `pvVarPutCallback'
> seq/O.linux-x86_64/../seq_if.c:538: undefined reference to
> `pvSysFlush'
> seq/O.linux-x86_64/../seq_if.c:529: undefined reference to
> `freeListFree'
> linux-x86_64/libseq.a(seq_if.o): In function `seq_pvGetTmo':
> seq/O.linux-x86_64/../seq_if.c:223: undefined reference to
> `freeListMalloc'
> seq/O.linux-x86_64/../seq_if.c:232: undefined reference to
> `pvVarGetCallback'
> seq/O.linux-x86_64/../seq_if.c:252: undefined reference to
> `pvSysFlush'
> seq/O.linux-x86_64/../seq_if.c:244: undefined reference to
> `freeListFree'
> linux-x86_64/libseq.a(seq_if.o): In function `seq_pvFlush':
> seq/O.linux-x86_64/../seq_if.c:952: undefined reference to
> `pvSysFlush'
> linux-x86_64/libseq.a(seq_qry.o): In function `seqShow':
> seq/O.linux-x86_64/../seq_qry.c:90: undefined reference to
> linux-x86_64/libseq.a(seq_cmd.o): In function
> `createOrAttachPvSystem':
> seq/O.linux-x86_64/../seq_cmd.c:61: undefined reference to
> `pvSysAttach'
> seq/O.linux-x86_64/../seq_cmd.c:56: undefined reference to
> `pvSysCreate'
> collect2: ld returned 1 exit status
> make[4]: *** [snc] Error 1
> make[4]: Leaving directory
> `/local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/seq-2-2-1/src
> /snc/O.linux-x86_64' make[3]: *** [install.linux-x86_64] Error 2
> make[3]: Leaving directory
> /snc' make[2]: *** [snc.install] Error 2
> make[2]: Leaving directory
> ' make[1]: *** [src.install] Error 2
> make[1]: Leaving directory
> `/local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/seq-2-2-1'
> make: ***
> [/local/DPbin/epics/epics_2015-03-31/synApps_5_8/support/seq-2-2-1.ins
> tall] Error 2
> Let me know if you need anything else,
> Matt
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: sseq 2-2-1 issue/bug Benjamin Franksen
Prev: RE: Can you stop script execution with adPython for AreaDetector? tom.cobb
Next: Re: sseq 2-2-1 issue/bug Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sseq 2-2-1 issue/bug Benjamin Franksen
