1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15.1 documentation...
To: <[email protected]>
Date: Fri, 20 Feb 2015 14:51:31 -0600
Hi David,
On 02/20/2015 12:56 PM, Dudley, David wrote:
> Has any of the documentation on the wiki been updated to begin
> reflecting the additional capabilities of 3.15.1?
Instead of using the Wiki we've started to include the documentation for
each record type in the record.dbd files using Perl's POD format, from
where we can automatically extract the information for the field
description tables and generate a separate HTML file for each record
type. The necessary tools to do that are included in 3.15.1, but if you
look in your base-3.15.1/html directory you'll see that we haven't got
terribly far through the list of records yet. Unfortunately the manual
conversion and update process is rather boring since I started (with the
ai and ao records) doing major rewrites of their descriptions to remove
cruft and make the text more useful.
I should probably put something on the Wiki explaining all this.
I would be very happy for any help the community can offer to this
project, but I am looking for the record descriptions to be rewritten to
match the current code and some additional sections added, not just the
conversion of the current Wiki pages into POD format.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
    against your wishes, and doesn't give you the key, they're
    not doing it for your benefit.
3.15.1 documentation... Dudley, David
Prev: Vacuum GUI: Vac. Status and Pumping Procedural Aid Crisp, Daniel
Next: synApps_5_7 build error (sscanSupport.dbd) Specht, Eliot D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 3.15.1 documentation... Dudley, David
Next: Vacuum GUI: Vac. Status and Pumping Procedural Aid Crisp, Daniel
