1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS_CA_ADDR_LIST question
To: Chen Xue <[email protected]>
Date: Mon, 23 Feb 2015 20:24:35 +0000
You don't need to fix anything. That is a normal warning that your IOC may not be reachable using UDP unicast, but you will be using broadcast so it won't be a problem.
Sent from my iPhone
> On Feb 23, 2015, at 12:41 PM, Chen Xue <[email protected]> wrote:
> Hi, there,
> I have multiple IOCs in a same host. I set up my EPICS_CA_ADDR_LIST to its
> broadcast address of IOC host as "1.2.3.255" instead of its IP address
> "1.2.3.4" or localhost. But when I started IOC, I still got the warning as
> below.
> cas warning: Configured TCP port was unavailable.
> cas warning: Using dynamically assigned TCP port xxx,
> cas warning: but now two or more servers share the same UDP port.
> cas warning: Depending on your IP kernel this server may not be
> cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
> iocRun: All initialization complete
> BTW, my IOC host and client are in the same subnet.
> How should I fix it?
> Thanks,
> Chen
EPICS_CA_ADDR_LIST question Chen Xue
Prev: Re: EPICS_CA_ADDR_LIST question Kasemir, Kay
Next: FW: EPICS_CA_ADDR_LIST question Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
