1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Regarding EPICS EDM-1-12-98
To: "Sinclair,John William" <[email protected]>, "[email protected]" <[email protected]>, [email protected], "Smt. Bhavna N. Merh" <[email protected]>
Cc: "T. A. Puntambekar" <[email protected]>, "Anil C. Holikatti" <[email protected]>
Date: Tue, 24 Feb 2015 12:51:06 +0530
Hello all,
After many trials, it seems that I have installed edm-1-12-98 successfully
on my PC (linux-x86), but when I run edm command, I get following error
message:-
rahul@RahulJain-PC:~$ edm
X error: code=3, msg: BadWindow (invalid Window parameter)
Error: No realize class procedure defined
Please suggest me how to fix this error. I have used following
configurations before running the edm command.
export EPICS_BASE=/opt/myepics/base
export EPICS_HOST_ARCH=linux-x86
export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH
export EPICS_EXTENSIONS=/opt/myepics/extensions
export PATH=$PATH:$EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
export
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
cd $HOME
mkdir edm
mkdir edm/prefs
export EDMOBJECTS=$HOME/edm/prefs
export EDMDATAFILES=$HOME/edm
export EDMFILES=$HOME/edm/prefs
export EDMPVOBJECTS=$HOME/edm/prefs
export EDMHELPFILES=/opt/myepics/extensions/src/edm/helpFiles
edm -add /opt/myepics/extensions/lib/linux-x86/libEdmBase.so
edm -add
/opt/myepics/extensions/lib/linux-x86/libcfcaa62e-8199-11d3-a77f-00104b8742df.so
edm -add
/opt/myepics/extensions/lib/linux-x86/libcf322683-513e-4570-a44b-7cdd7cae0de5.so
edm -add
/opt/myepics/extensions/lib/linux-x86/lib7e1b4e6f-239d-4650-95e6-a040d41ba633.so
edm -add
/opt/myepics/extensions/lib/linux-x86/lib57d79238-2924-420b-ba67-dfbecdf03fcd.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libEpics.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libCalc.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libLoc.so
edm -addpv /opt/myepics/extensions/lib/linux-x86/libLog.so
cd $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/setup/calc.list $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/setup/colors.list $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/setup/fonts.list $HOME/edm/prefs
cp /opt/myepics/extensions/src/edm/edmMain/edmPrintDef $HOME/edm/prefs
With best regards
Rahul Jain
BDS/ACBDD
RRCAT, Indore
Ph.:0731-244-2555
Mob.:08989006799
Prev: Importing cs-studio into eclipse Xinyu.Wu
Next: Re: using EPICS code with HTTP port Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Importing cs-studio into eclipse Richard Fearn
Next: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
