1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Begginer with EPICSv4
To: [email protected]
Date: Tue, 24 Feb 2015 11:46:18 +0100
Hello all,
I´m a newbie in this environment and I´m trying to understand EPICSv4, I have tried examples HelloWorld and rdbService from example JAVA in the last release from EPICSv4-JAVA. Now I´m trying to make a classical example of a PVServer generating data and clients trying to get it automatically, so I have a pair of questions that maybe you can help me to solve.
First: I think that I should try using Monitor to publish/suscribe for automatic onChange working between a PVServer and a Client, AM I right? Second: The General architecture for monitor seems a bit complex to me and I need some help to Undestand it. Here are my thoughts and I want to Know if I´m right or where I´m mistaken:
First you start the client with ClientFactory.start(). In the client side you need to get to a ChannelProvider (in this case "pva"). Then you have to create a Channel from the Provider (but you need a ChannelRequester and I don´t know if I just have to create the object or find it in the net). Continuining with the creation of a PVStructure you can then create also the Monitor (But I don´t know if when I create the channel, this channel has to be a ChannelRPC or not). Also, Is the requester of the monitor the same as the requester of the Channel creation?. Finally I don´t see the structure of the MonitorElement, and when I create the Monitor, do I have to make a while loop where I write the commando FOR for the monitor and get there the MonitorElement?
In the server side I´m even more lost, as I have seen the createMonitor in ChannelRPC, but I can´t see any of the parameters configuration (such as the term onChange) that it´s mentioned in the documentation about Monitor.
If anyone has tested this, I would gladly accept any help.
Thanks in advance, Ricardo
Doctorando i2a2
Jefe de Servicio de Instalaciones - CEDEX
Re: Begginer with EPICSv4 Pearson, Matthew R.
Re: Begginer with EPICSv4 Kasemir, Kay
Prev: Re: Importing cs-studio into eclipse Jani Hakala
Next: Re: Importing cs-studio into eclipse Xinyu.Wu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS - subarray display bug Amien Crombie [TLABS]
Next: Re: Begginer with EPICSv4 Pearson, Matthew R.
