1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multiple interrupt callback for waveform record
To: "'Vishnu Patel'" <[email protected]>, "techtalk " <[email protected]>
Date: Tue, 24 Feb 2015 21:21:57 +0000
Hi Vishnu,
> Do any one doing multiple callback for same channel till all the buffered data pushed out to waveform record with same interrupt node?
I don’t think that is possible.
This the relevant code snippet:
static void interruptCallback(void *drvPvt, asynUser *pasynUser,                                   \
                EPICS_TYPE *value, size_t len)                                                     \
    devAsynWfPvt *pPvt = (devAsynWfPvt *)drvPvt;                                                   \
    waveformRecord *pwf = (waveformRecord *)pPvt->pr;                                              \
    int i;        \
    EPICS_TYPE *pData = (EPICS_TYPE *)pwf->bptr;                                                   \
        dbScanLock((dbCommon *)pwf);                                                               \
        if (len > pwf->nelm) len = pwf->nelm;                                                      \
        for (i=0; i<(int)len; i++) pData[i] = value[i];                                            \
        pwf->time = pasynUser->timestamp;                                                          \
        pPvt->gotValue++;        \
        pPvt->nord = (epicsUInt32)len;                                                             \
        if (pPvt->status == asynSuccess) pPvt->status = pasynUser->auxStatus;                      \
        dbScanUnlock((dbCommon *)pwf);                                                             \
        if (pPvt->isOutput)        \
            scanOnce((dbCommon *)pwf);                                                             \
        else        \
            scanIoRequest(pPvt->ioScanPvt);                                                        \
So your driver passes “*value” (pointer to array) and “len” (number of elements in array) to the callback function.  If NELM is less than “len” it only copies NELM elements.  It does not pass back the actual number of elements copied to your driver, so your driver would not know how to loop.
You could send NELM to your driver by some mechanism, and then your driver could loop.  However, you would need to enable ring buffers in the waveform record device support, otherwise it is likely that when you do the callback for the next loop you will simply overwrite the data from the previous callback, because the record will not have had a chance to process yet.
Why are you trying to set NELM less than 100?
From: [email protected] [mailto:[email protected]] On Behalf Of Vishnu Patel
Sent: Tuesday, February 24, 2015 2:39 PM
To: techtalk
Subject: multiple interrupt callback for waveform record
   In my asynDriver based driver, i am acquiring 100 data points in the poling mode and then call interrupt callback for waveform record for each channel.
  If i keep my NELM field more than 100 in the application waveform record, it works fine and i am not loosing any data. but if application have waveform record   NELM less then 100, i am loosing data.
I tried to run loop for calling interrupt call back function upto 100 data points over but it seems it doesn't call callback after once called.  and need end and restart interrupt.
The way i am calling interrupt is as below with addr=channel number.
if (interrupt[addr]) {
                                                            p_interruptFloat32Array->pasynUser->auxStatus = interrupt_status[addr];
                                                            p_interruptFloat32Array->callback(p_interruptFloat32Array->userPvt,
        p_interruptFloat32Array->pasynUser, buffer[addr], threshold);
Thanks
Vishnu
Get your own FREE website, FREE domain & FREE mobile app with Company email.
Know More >
multiple interrupt callback for waveform record Vishnu Patel
Prev: multiple interrupt callback for waveform record Vishnu Patel
Next: Re: Using the EPICS Build/Make system to build kernel modules for linux J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: problem with pointGreyApp.exe using AD 2-1 Alireza Panna
