1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: problem with pointGreyApp.exe using AD 2-1
To: "'Alireza Panna'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 25 Feb 2015 19:14:07 +0000
Hi Alireza,
The problem is that you have built pointgrayApp as a dynamic executable, so it requires being able to find not only pointGrey.dll, but also all of the other DLLs in EPICS base and synApps.
If you defined ARCH=windows-x64 in ADPointGrey/iocs/iocPointGrey/iocBoot/iocPointGrey/Makefile, then that directory should contain a file called dllPath.bat.  If not, edit the Makefile to set ARCH=windows-x64 and run “make clean”, “make”, which will create dllPath.bat.  You need to execute that batch file once per Windows session before executing the pointGreyApp application.  That batch file will define your PATH so it will find all of the required DLLs.  From the iocPointGrey directory:
.\dllPath.bat
..\..\bin\windows-x64\pointGreyApp st.cmd
Let me know if you have problems or questions.
From: [email protected] [mailto:[email protected]] On Behalf Of Alireza Panna
Sent: Wednesday, February 25, 2015 1:03 PM
To: [email protected]
Subject: problem with pointGreyApp.exe using AD 2-1
Hello tech-talkers,
I am having trouble running the pointGreyApp executable ( I did not get errors during compile time of ADPointGrey). The error says that pointGrey.dll is missing, however, I see that it is present in C:\Epics\support\areaDetector-2-1\ADPointGrey\bin\windows-x64
Maybe I missed some path definition but I can't figure it out. Below is my  envPath:
epicsEnvSet("ARCH","windows-x64")
epicsEnvSet("IOC","iocPointGrey")
epicsEnvSet("TOP","C:/Epics/support/areaDetector-2-1/ADPointGrey/iocs/pointGreyIOC")
epicsEnvSet("ADPOINTGREY","C:/Epics/support/areaDetector-2-1/ADPointGrey")
epicsEnvSet("SUPPORT","C:/Epics/support")
epicsEnvSet("AREA_DETECTOR","C:/Epics/support/areaDetector-2-1")
epicsEnvSet("EPICS_BASE","C:/Epics/base-3.14.12.4")
epicsEnvSet("ASYN","C:/Epics/support/asyn-4-26")
epicsEnvSet("ADCORE","C:/Epics/support/areaDetector-2-1/ADCore")
epicsEnvSet("CALC","C:/Epics/support/calc-3-4-2")
#epicsEnvSet("BUSY","C:/Epics/support/busy-1-6")
epicsEnvSet("SSCAN","C:/Epics/support/sscan-2-10")
epicsEnvSet("AUTOSAVE","C:/Epics/support/autosave-5-5")
I have the flycapture viewer installed along with their sdk as well. Epics base and Area detector are compiled dynamically (using MS Visual Studio 12).
Any help will be appreciated.
Alireza Panna
University of Maryland, College Park
problem with pointGreyApp.exe using AD 2-1 Alireza Panna
Prev: problem with pointGreyApp.exe using AD 2-1 Alireza Panna
Next: Re: problem with pointGreyApp.exe using AD 2-1 Zachary Brown
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
