1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error in compiling areaDetector
To: GONG Yu <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 26 Feb 2015 03:09:03 +0000
Which version of ADCore are you using?
Where is libxml/xmlreader.h located on your system.
The next release of areaDetector/configure/EXAMPLE_CONFIG_SITE.local allows you to define XML2_INCLUDE, and that directory is added to USR_INCLUDES.  In R2-1 USR_INCLUDES just adds  -I/usr/include/libxml2.  If that is where your libxml/xmlreader.h is located then it should work.
From: [email protected] [[email protected]] on behalf of GONG Yu [[email protected]]
Sent: Wednesday, February 25, 2015 8:56 PM
To: [email protected]
Subject: Error in compiling areaDetector
Hello everyone,
    I am running to the error when I compile the areaDetector module.
    The errors are listed below:
In file included from ../NDFileHDF5.h:15,
                 from ../NDFileHDF5.cpp:33:
../NDFileHDF5LayoutXML.h:11:30: warning: libxml/xmlreader.h: No such file or directory
../NDFileHDF5Layout.h:112: warning: ‘class hdf5::Element’ has virtual functions but non-virtual destructor
../NDFileHDF5LayoutXML.h:111: error: ‘xmlTextReaderPtr’ does not name a type
make[4]: *** [NDFileHDF5.o] Error 1
make[4]: Leaving directory `/home/gongyu/areaDetector-R2-0/ADCore/ADApp/pluginSrc/O.linux-x86'
make[3]: *** [install.linux-x86] Error 2
make[3]: Leaving directory `/home/gongyu/areaDetector-R2-0/ADCore/ADApp/pluginSrc'
make[2]: *** [pluginSrc.install] Error 2
make[2]: Leaving directory `/home/gongyu/areaDetector-R2-0/ADCore/ADApp'
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory `/home/gongyu/areaDetector-R2-0/ADCore'
make: *** [ADCore.install] Error 2
The products that have been built or installed are listed belows:
EPICS base 3.14.12.4
asyn4-25
synApps (autosave-5-1,busy-1-6,calc-3-2,sscan-2-9)
libtiff (tiff-4.0.4beta)
zlib (zlib-1.2.8)
libjpeg (libjpeg-turbo-1.4.0)
szip (szip-2.1)
hdf5 (hdf5-1.8.12)
My operating system is 32bit CentOS 5.6
After this error, I install the libxml2 (libxml2, libxml2-devel and zlib-devel requied by libxml2-devel) by using RPM, then I rebuild the zlib and hdf5. But when I compile the areaDetector module, I still get the same error.
I do not know how to solve this problem, can anyone help me?
Thank you,
gongyu
Error in compiling areaDetector GONG Yu
Prev: Error in compiling areaDetector GONG Yu
Next: CSS - Boolean switch Amien Crombie [TLABS]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: RE: Error in compiling areaDetector Mark Rivers
