Hi Mark,
Yes! That was it. I should have looked at those files more carefully- one more thing though, I have not had this error before so I am not sure how to deal with it. Any ideas? KsApp_registerRecordDeviceDriver.obj : error LNK2001: unresolved external symbol pvar_func_KsRegister KsApp.exe : fatal error LNK1120: 1 unresolved externals C:/base-3.14.12.4/configure/RULES_BUILD:183: recipe for target 'KsApp.exe' failed make[5]: *** [KsApp.exe] Error 1120 make[5]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src/O.windows-x64' Thanks! Andrew Full output: make -C ./configure install make[1]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. T_A=windows-x64 install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure/O.windows-x64' perl C:/base-3.14.12.4/bin/windows-x64/convertRelease.pl checkRelease make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure/O.windows-x64' make[1]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/configure' make -C ./KsApp install make[1]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp' make -C ./src install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src/O.windows-x64' "Installing dbd file ../../../dbd/KsSupport.dbd" mkdir ../../../dbd cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\base-3.14.12.4\\include -IC:\\support\\asyn-4-26\\include -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include -IC:\\support\\areaDetector-R2-0\\ADCore\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADCore\\include ..\\Ks.cpp Ks.cpp ..\Ks.cpp(435) : warning C4101: 'pstInfo' : unreferenced local variable lib /nologo /verbose /out:Ks.lib /LTCG Ks.obj Appending Ks.obj "Installing library ../../../lib/windows-x64/Ks.lib" mkdir ../../../lib mkdir ../../../lib/windows-x64 make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src/O.windows-x64' make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/src' make -C ./Db install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db/O.windows-x64' "Installing db file ../../../db/Ks.template" mkdir ../../../db make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db/O.windows-x64' make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp/Db' make[1]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/KsApp' make -C ./iocs install make[1]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs' make -C ./KsIOC install make[2]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC' make -C ./configure install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../.. T_A=windows-x64 install make[4]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure/O.windows-x64' perl C:/base-3.14.12.4/bin/windows-x64/convertRelease.pl checkRelease make[4]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure/O.windows-x64' make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/configure' make -C ./KsApp install make[3]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp' make -C ./src install make[4]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src' perl C:/base-3.14.12.4/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[5]: Entering directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src/O.windows-x64' perl C:/base-3.14.12.4/bin/windows-x64/makeIncludeDbd.pl KsSupport.dbd commonDriverSupport.dbd KsAppInclude.dbd echo "../O.Common/KsAppInclude.dbd : ../Makefile" >> KsApp.dbd.d "Expanding dbd" "Installing created dbd file ../../../dbd/KsApp.dbd" mkdir ../../../dbd perl C:/base-3.14.12.4/bin/windows-x64/registerRecordDeviceDriver.pl ../O.Common/KsApp.dbd KsApp_registerRecordDeviceDriver C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC > KsApp.tmp perl -MExtUtils::Command -e mv KsApp.tmp KsApp_registerRecordDeviceDriver.cpp cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\base-3.14.12.4\\include -IC:\\support\\asyn-4-26\\include -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include -IC:\\support\\areaDetector-R2-0\\ADCore\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADCore\\include -IC:\\support\\calc-3-2\\include -IC:\\support\\busy-1-6\\include -IC:\\support\\sscan-2-9\\include -IC:\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\support\\autosave-5-1\\include KsApp_registerRecordDeviceDriver.cpp KsApp_registerRecordDeviceDriver.cpp cl /nologo /EHsc /GR -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\base-3.14.12.4\\include\\os\\WIN32 -IC:\\base-3.14.12.4\\include -IC:\\support\\asyn-4-26\\include -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADBinaries\\include -IC:\\support\\areaDetector-R2-0\\ADCore\\include\\os\\WIN32 -IC:\\support\\areaDetector-R2-0\\ADCore\\include -IC:\\support\\calc-3-2\\include -IC:\\support\\busy-1-6\\include -IC:\\support\\sscan-2-9\\include -IC:\\support\\autosave-5-1\\include\\os\\WIN32 -IC:\\support\\autosave-5-1\\include ..\\KsAppMain.cpp KsAppMain.cpp link -nologo /LTCG /incremental:no /opt:ref /release /MACHINE:X64 /NODEFAULTLIB:MSVCRT.lib -out:KsApp.exe KsApp_registerRecordDeviceDriver.obj KsAppMain.obj C:\\support\\areaDetector-R2-0\\ADNikonKs\\lib\\windows-x64\\Ks.lib C:\\support\\areaDetector-R2-0\\ADCore\\lib\\windows-x64\\NDPlugin.lib C:\\support\\areaDetector-R2-0\\ADCore\\lib\\windows-x64\\ADBase.lib C:\\support\\areaDetector-R2-0\\ADCore\\lib\\windows-x64\\netCDF.lib C:\\support\\areaDetector-R2-0\\ADCore\\lib\\windows-x64\\NeXus.lib C:\\support\\calc-3-2\\lib\\windows-x64\\calc.lib C:\\support\\busy-1-6\\lib\\windows-x64\\busy.lib C:\\support\\sscan-2-9\\lib\\windows-x64\\sscan.lib C:\\support\\autosave-5-1\\lib\\windows-x64\\autosave.lib C:\\support\\asyn-4-26\\lib\\windows-x64\\asyn.lib C:\\base-3.14.12.4\\lib\\windows-x64\\recIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\softDevIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\miscIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\rsrvIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\dbtoolsIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\asIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\dbIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\registryIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\dbStaticIoc.lib C:\\base-3.14.12.4\\lib\\windows-x64\\ca.lib C:\\base-3.14.12.4\\lib\\windows-x64\\Com.lib C:\\support\\areaDetector-R2-0\\ADCore\\lib\\windows-x64\\tiff.lib C:\\support\\areaDetector-R2-0\\ADCore\\lib\\windows-x64\\jpeg.lib C:\\support\\areaDetector-R2-0\\ADBinaries\\lib\\windows-x64\\hdf5.lib C:\\support\\areaDetector-R2-0\\ADBinaries\\lib\\windows-x64\\libszip.lib C:\\support\\areaDetector-R2-0\\ADBinaries\\lib\\windows-x64\\zlib.lib C:\\support\\areaDetector-R2-0\\ADBinaries\\lib\\windows-x64\\libxml2.lib Gdi32.lib Oleaut32.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib KsApp_registerRecordDeviceDriver.obj : error LNK2001: unresolved external symbol pvar_func_KsRegister KsApp.exe : fatal error LNK1120: 1 unresolved externals C:/base-3.14.12.4/configure/RULES_BUILD:183: recipe for target 'KsApp.exe' failed make[5]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src/O.windows-x64' C:/base-3.14.12.4/configure/RULES_ARCHS:63: recipe for target 'install.windows-x64' failed make[4]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp/src' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'src.install' failed make[3]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC/KsApp' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'KsApp.install' failed make[2]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs/KsIOC' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'KsIOC.install' failed make[1]: Leaving directory 'C:/support/areaDetector-R2-0/ADNikonKs/iocs' C:/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'iocs.install' failed On Thu, Feb 26, 2015 at 11:05 PM, Mark Rivers <[email protected]> wrote: Hi Andrew,
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
