1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using sCalcout record
To: Chanaka De Silva <[email protected]>
Date: Mon, 2 Mar 2015 20:36:14 +0000
Hi Chanaka,
I'm not questioning your choice of an scalcout record.  I'm just asking what you want the record to do.  For example, what alarm should result from beam_state=='At Injection' while $(DEVICE):State=='ON', and so on.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Monday, March 02, 2015 1:31 PM
To: Mooney, Tim M.
Cc: [email protected]
Subject: Re: Using sCalcout record
Hi, Tim:
Thank you for the reply.
Why I decided sCalcout? I thought sCalcout is the record that can handle "String" inputs. I have used calcout record previously for such alarm variables. However I never had to handle a "String" as an input. May be I could do without sCalcout.
Thanks, Chanaka.
On Mar 2, 2015, at 2:10 PM, Mooney, Tim M. wrote:
> Hi Chanaka,
> I don't know what you want the scalcout record to do, but you might start with something like this:
> record(scalcout, "calcAlarmState") {
>    field(INAA, "beam_state CP")
>    field(INBB, "$(DEVICE):State CP")
>    field(CALC, ("aa=='At Injection' && bb=='OFF') ? 'WARN' : 'OK'")
>    field(OUT, "warning_BeamInjection PP")
> record(bo, "warning_BeamInjection") {
>    field(ZNAM, "OK")
>    field(ONAM, "WARN"
>    field(ZSV, "NO_ALARM")
>    field(OSV, "MAJOR")
> From: [email protected] [[email protected]] on behalf of Chanaka De Silva [[email protected]]
> Sent: Monday, March 02, 2015 2:20 AM
> To: [email protected]
> Subject: Using sCalcout record
> Dear, all
> I am in need of developing an alarm variable using the sCalcout record.
> I plan to input two variables that are defined as follows.
> 1.
> grecord(stringout,"beam_state")
> 2.
> record(bi, "$(DEVICE):State")
>       field(DESC, "Power Supply On/Off Status")
>       field(DTYP, "stream")
>       field(INP, "@genesys.proto PSU-getonoff $(IP)")
>       field(ZNAM, "OFF")
>       field(ONAM, "ON")
>       field(ZSV,  "MAJOR")
>       field(OSV,  "NO_ALARM")
>       field(PINI, "YES")
>       field(FLNK, "$(DEVICE):Limits")
> I decided to use sCalcout since both of these variables output strings.
> For example;
> The first record outputs; "At Injection"
> The second record outputs; "ON"
> I looked up the documentation and could not figure out what is the best approach to write a record to define an alarm variable; let's say
> record(scalcout, warning_BeamInjection){
> I plan to have 1 or 0 assigned to this alarm variable, so that I can set my HIHI alarm to sit at "1".
> Any help is much appreciated.
> Thanks, Chanaka.
Re: Using sCalcout record Chanaka De Silva
RE: Using sCalcout record Mooney, Tim M.
Prev: Experience with Nutaq devices Greg Tchilinguirian
Next: Re: Using sCalcout record Chanaka De Silva
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using sCalcout record Chanaka De Silva
