1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM: seeking larger menus and text editing widgets
To: [email protected]
Date: Thu, 05 Mar 2015 10:37:05 -0500
Hi Jon,
EDM does not explicitly specify fonts for the normal windows and menus. To get the font you desire, do the following:
1) Choose a font
    - do xlsfonts to get a list of possibilites
- for this example, suppose you choose -misc-fixed-medium-r-normal--20-200-75-75-c-100-iso8859-1
2) Edit .Xresources in your home directory and add a line that reads
    edm*fontList: -misc-fixed-medium-r-normal--20-200-75-75-c-100-*-*
3) Load the X resources with one of the following command:
xrdb ~/.Xresources (this discards existing resources)
    xrdb -merge ~/.Xresources        (this keeps existing resources)
4) run edm
    The menu font should now be fairly large.
You will have to include the xrdb command in some login file (e.g. .bashrc).
Best regards,
John Sinclair
On 03/04/2015 02:58 PM, [email protected] wrote:
In EDM, is there some way to make the menu larger, that appears when
you click on a menu button?  It is easy in EDM to set the size of the
menu button and its text, but the menu (and its text) that appears
when we click the button is always the same size - which is
uncomfortably small on our 1680 x 1050 displays.
Likewise, the text editing widget that appears when we click on an
editable text control is also too small - we would like to
enlarge that too.
Jon Jacky
EDM: seeking larger menus and text editing widgets jon
Prev: waveProc maintainer? Michael Davidsaver
Next: Re: waveProc maintainer? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM: seeking larger menus and text editing widgets jon
Next: Problem with HDF5 plugin for areaDetector Wilkins, Stuart
