1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: acalcout subarray indices
To: "Mooney, Tim M." <[email protected]>
Date: Thu, 5 Mar 2015 13:55:45 -0800 (PST)
The discrepancy arises because we tested calc-2-8 but the documentation applies to 3-0 and later.   The student whose tool revealed the discrepancy also found this:
From http://www.aps.anl.gov/bcda/synApps/calc/calcReleaseNotes.html, in the upgrade
to version 3-0:
WARNING! NON-BACKWARD-COMPATIBLE CHANGE:
Fixed the array calc {} (subrange in place) operator to treat array indices as documented
- exactly as the [] (subrange) operator treats them. Previously, for example, aa{0,n} was
not the same as aa[0,n], but instead performed aa{0,n-1}.
My test IOC is running version 3-2, and your code is on 2-8, hence the difference!
So, the interpreter is correct according to the docs and the current version, but wrong
with respect to the code you guys are running.
On Thu, 5 Mar 2015, Mooney, Tim M. wrote:
Hi Jon,
What is the value of R.B?
When I use that expression, I don't get that result, unless R.B==-1.
There is a test whose results seem clearer to me:
R.CALC=IX
caget -#6 R.AVAL -> R.AVAL 6    0 1 2 3 4 5
CALC = IX{2,4}
caget -#6 R.AVAL -> R.AVAL 6    0 0 2 3 4 0
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Wednesday, March 04, 2015 7:01 PM
To: [email protected]
Subject: acalcout subarray indices
This documentation on the acalcout record:
http://www.aps.anl.gov/bcda/synApps/calc/R2-6/aCalcoutRecord.html
says that subarray indices are inclusive, so that {2,4} selects
elments with indices 2,3,4 (where 0 is the first index):
AA{2,4} where AA = (1,2,3,4,5,6)  Result is (0,0,3,4,5,0).
But this test seems to show that indices are exclusive, that is,
the upper index is excluded from the subarray:
record(acalcout, R) {
 field(NELM, "2")
 # no INPA or INPB - write directly to R.A and R.B
 field(CALC, "ARR(0)+ARR(A){0,1}+ARR(B){1,2}")
epics> dbgf R.AVAL
DBR_DOUBLE[2]:      0                   0
epics> dbpf R.A 1
DBR_DOUBLE:         1
epics> dbgf R.AVAL
DBR_DOUBLE[2]:      1                   0
According to the documentation, it seems {0,1} should select the two
elements with indices 0 and 1, but here only the first bit in AVAL
gets set.  Similar tests with larger arrays, subarrays longer than one
element, values other than 1, and positions other than the first, show
similar results: the upper index is not included in the subarray.
Can anyone explain this?
Jon Jacky
PS - This discrepancy was found by a graduate student here at UW, who
wrote an analyzer that checks an EPICS database against assertions about
its intended behavior.
RE: acalcout subarray indices Mooney, Tim M.
Prev: RE: IOC shell message for waveform record Mark Rivers
Next: RE: asyn R4.26 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: acalcout subarray indices Mooney, Tim M.
Next: waveProc maintainer? Michael Davidsaver
