1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with libhdf5.a when installling areaDetector-2-1
To: Cristian Savlovschi <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 6 Mar 2015 16:37:06 +0000
Hi Cristi,
I don't understand this error message:
/usr/bin/ld: /opt/epics/areaDetector-2-1/ADCore/lib/linux-x86_64/libhdf5.a
There should not be a libhdf5.a in that directory.  libhdf5 should be in some directory outside of ADCore.  It looks like in your case you are building hdf5 in /usr/local/hdf5.  Where did that file in ADCore/lib/linux-x86_64 come from?
Here is the contents of the ADCore/lib/linux-x86_64/ directory on my system after a successful build of ADCore.
/home/epics/devel/areaDetector/ADCore/lib/linux-x86_64
corvette:ADCore/lib/linux-x86_64>ls -l
total 15728
-r--r--r-- 1 epics epics 1649396 Mar  5 15:36 libADBase.a
-r-xr-xr-x 1 epics epics  727178 Mar  5 15:36 libADBase.so
-r--r--r-- 1 epics epics 5930442 Mar  6 09:57 libNDPlugin.a
-r-xr-xr-x 1 epics epics 2518160 Mar  6 09:57 libNDPlugin.so
-r--r--r-- 1 epics epics  483936 Mar  5 15:36 libNeXus.a
-r-xr-xr-x 1 epics epics  262674 Mar  5 15:36 libNeXus.so
-r--r--r-- 1 epics epics 2299174 Mar  5 15:36 libnetCDF.a
-r-xr-xr-x 1 epics epics 1645681 Mar  5 15:36 libnetCDF.so
-r--r--r-- 1 epics epics  373970 Mar  5 15:40 libsimDetector.a
-r-xr-xr-x 1 epics epics  194233 Mar  5 15:40 libsimDetector.so
From: [email protected] [[email protected]] on behalf of Cristian Savlovschi [[email protected]]
Sent: Friday, March 06, 2015 6:44 AM
To: [email protected]
Subject: Problem with libhdf5.a when installling areaDetector-2-1
I’m trying to create a demo project based on EPICS, in the following configuration:
IOC (CA server) running on UBUNTU 14.04 linux-x86_64
CA Client (CSS) running on Windows 8
I’ve installed  EPICS Base 3.14.12.4 + synApps 5.7 succesfully and was able to run the IOC for DG645 delay generator and connect to the hw device.
Now I’m stuck on the next step, which is to install another IOC application, for a Point Grey Flea3 CCD camera.
The driver for this device has been added to areaDetector package starting with release 2.0 (Apr 2014). The most recent version of areaDetector in synApps (at present time - March 2015) is 1.9.1, therefore I’ve decided to update this package. I’ve downloaded it from github and tried to install it in a separate ‘TOP’ folder following the installation instructions in https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
After customizing all the configuration files and installing all 3rd party packages, my ‘make’ is failing with the following error message:
            make[4]: Entering directory `/opt/epics/areaDetector-2-1/ADCore/ADApp/nexusSrc/O.linux-x86_64'
            /usr/bin/g++ -o libNeXus.so -shared -fPIC -Wl,-hlibNeXus.so -L/opt/epics/areaDetector-2-1/ADCore/lib/linux-x86_64 -Wl,-rpath,/opt/epics/areaDetector-2-1/ADCore/lib/linux-x86_64       -m64                napi.o napi5.o napiu.o nxdataset.o nxio.o nxstack.o nxxml.o stptok.o   -lhdf5 -lsz   -lpthread   -lreadline -lm -lrt -ldl -lgcc
            /usr/bin/ld: /opt/epics/areaDetector-2-1/ADCore/lib/linux-x86_64/libhdf5.a(H5.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
            /opt/epics/areaDetector-2-1/ADCore/lib/linux-x86_64/libhdf5.a: error adding symbols: Bad value
            collect2: error: ld returned 1 exit status
I cannot get pass this point, even after trying to rebuild the HDF5 package with additional –fPIC flag:
LDFLAGS=-fPIC ./configure --prefix=/usr/local/hdf5 --with-szlib=/usr/local
Any suggestions?
Note that I’m a EPICS & Linux beginner (~1 month)..
Thanks!
Cristi S
RE: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
Prev: Re: cross compiling EPICS Base fails Florian Feldbauer
Next: caQtDM Compile Error: qwt_thermo_marker.cpp Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
Next: RE: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
