Sent from my iPhone
> On Mar 9, 2015, at 12:07 AM, Mezger Anton Christian (PSI) <[email protected]> wrote:
> Hi Ernesto,
> I updated the table and it can be viewed on our site.
Sounds good
> For building caQtDM, do not use qmake directly. You should use the schell script caQtDM_BuildAll. I hope it will work like that.
Indeed, the compile error happens when using the build script
-- Ernesto
> Best regards
> Anton
> -----Original Message-----
> From: Williams Jr., Ernest L. [mailto:[email protected]]
> Sent: Sonntag, 8. März 2015 04:48
> To: Mezger Anton Christian (PSI)
> Cc: Babbitt, Alisha; [email protected]; Williams Jr., Ernest L.
> Subject: caQtDM Compile Error: qwt_thermo_marker.cpp
> Hi Anton,
> Here it SLAC we are heavy EDM users.
> Time to checkout caQtDM :)
> I will also want to give your converter tool a try: "edl2ui"
> Any new updates on the conversion table?
> http://www.aps.anl.gov/epics/tech-talk/2015/msg00137.php
> But, I am having trouble building :(
> I am trying to build the caQtDM for RHEL6 x86_64 I am also attempting to build on Fedora 21 x86_64 I get the same compile error message for "qwt_thermo_marker.cpp"
> RHEL6 ==>
> caQtDM Version: 3.8.10
> qmake -version
> QMake version 2.01a
> Using Qt version 4.6.2 in /usr/lib64
> qt-devel-4.6.2-28.el6_5.x86_64
> QWT VERSION: qwt-6.1.0
> QtDesigner Version 4.6.2
> /usr/include/QtDesigner
> Compile Error Below:
> g++ -c -m64 -pipe -g -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2
> g++ -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
> g++ -Wall -W -D_REENTRANT -fPIC -DIO_OPTIMIZED_FOR_TABWIDGETS
> g++ -DQT_NO_DEBUG_OUTPUT -DQT_NO_DEBUG -DQT_PLUGIN -DQT_SCRIPT_LIB
> g++ -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQDESIGNER_EXPORT_WIDGETS
> g++ -I/usr/lib64/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/QtUiTools
> g++ -I/usr/include/QtDesigner -I/usr/include/QtCore -I/usr/include/QtGui
> g++ -I/usr/include/QtXml -I/usr/include/QtScript -I/usr/include -Isrc
> g++ -I/afs/slac/g/lcls/package/qwt-6.1.0/include -Imoc -o
> g++ obj/moc_leftclick_with_modifiers_eater.o
> g++ moc/moc_leftclick_with_modifiers_eater.cpp
> In file included from src/qwt_thermo_marker.cpp:42:
> src/qwt_thermo_marker.h:111: warning: direct base 'QWidget' inaccessible in 'QwtThermoMarker' due to ambiguity
> src/qwt_thermo_marker.cpp: In function 'bool qwtIsLogarithmic(const QwtThermoMarker*)':
> src/qwt_thermo_marker.cpp:46: error: 'QwtScaleTransformation' has not been declared
> src/qwt_thermo_marker.cpp:46: error: expected initializer before 'scaleType'
> src/qwt_thermo_marker.cpp:49: error: 'scaleType' was not declared in this scope
> src/qwt_thermo_marker.cpp:49: error: 'QwtScaleTransformation' has not been declared
> src/qwt_thermo_marker.cpp: At global scope:
> Fedora 21 ==>
> qmake -version
> QMake version 2.01a
> Using Qt version 4.8.6 in /usr/lib64
> qt-devel-4.8.6-18.fc21.x86_64
> QWT VERSION: qwt-6.1.2-1.fc21.x86_64
> QtDesigner Version 4.8.6
> g++ -c -pipe -g -O2 -g -pipe -Wall -Werror=format-security
> g++ -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector-strong
> g++ --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic
> g++ -O2 -Wall -W -D_REENTRANT -fPIC -DIO_OPTIMIZED_FOR_TABWIDGETS
> g++ -DQWT_DLL -DQT_SHARED -I/usr/lib64/qt4/mkspecs/linux-g++ -I.
> g++ -I/usr/include/QtUiTools -I/usr/include/QtDesigner
> g++ -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include/QtXml
> g++ -I/usr/include/QtScript -I/usr/include -Isrc -I/usr/include/qwt
> g++ -Imoc -I/usr/include/qwt -o obj/moc_camenu.o moc/moc_camenu.cpp
> In file included from src/qwt_thermo_marker.cpp:42:0:
> src/qwt_thermo_marker.h:110:20: warning: direct base 'QWidget' inaccessible in 'QwtThermoMarker' due to ambiguity class QTCON_EXPORT QwtThermoMarker: public QWidget, public QwtAbstractScale
> src/qwt_thermo_marker.cpp:46:11: error: 'QwtScaleTransformation' does not name a type
> const QwtScaleTransformation::Type scaleType =
> src/qwt_thermo_marker.cpp:49:14: error: 'scaleType' was not declared in this scope
> return ( scaleType == QwtScaleTransformation::Log10 );
> Cheers,
> Ernesto
- caQtDM Compile Error: qwt_thermo_marker.cpp Williams Jr., Ernest L.
Re: caQtDM Compile Error: qwt_thermo_marker.cpp Ebner Simon Gregor (PSI)
<2015>
2025
2026
<2015>
2025
2026
