1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Database Builder Tool
To: <[email protected]>
Date: Mon, 9 Mar 2015 09:59:39 +0000
This is the first of a series of libraries and components that I am planning to publish.
Today I would like to bring your attention to https://github.com/Araneidae/epicsdbbuilder .  This is a tool designed to make it easy to build complex EPICS databases from Python scripts.  For example, this script:
from epicsdbbuilder import *
InitialiseDbd('/dls_sw/epics/R3.14.12.3/base/')
SetTemplateRecordNames()
a = records.ao('TEST')
c = records.calc('CALC', CALC = 'A+B', SCAN = '1 second', INPA = a.VAL)
c.INPB = c
WriteRecords('output.db')
generates the following epics .db file:
# This file was automatically generated on Mon 02 Mar 2015 12:57:13 GMT.
# *** Please do not edit this file: edit the source file instead. ***
#% macro, DEVICE, Device name
record(calc, "$(DEVICE):CALC")
    field(CALC, "A+B")
    field(INPA, "$(DEVICE):TEST.VAL")
    field(INPB, "$(DEVICE):CALC")
    field(SCAN, "1 second")
record(ao, "$(DEVICE):TEST")
This library has been extracted and simplified from the Diamond IOC builder, https://github.com/Araneidae/iocbuilder , also http://controls.diamond.ac.uk/downloads/python/iocbuilder .  We use this library to assemble numerous complex IOCs from support modules, but alas there are a lot of Diamond specific dependencies hard-wired into that module which we’ve not managed to abstract, so I know there’s been little if any external takeup of this library.
EPICS Db Builder is new, and the documentation will be rough, but the underlying framework (IOC builder) has been in use at Diamond for at least eight years now!
I would welcome any comments, particularly any problems with the documentation or suggestions for improvement.
Prev: RE: Problem with libhdf5.a when installling areaDetector-2-1 Cristian Savlovschi
Next: RE: Importing cs-studio into eclipse Richard Fearn
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caQtDM Compile Error: qwt_thermo_marker.cpp Williams Jr., Ernest L.
Next: Python Soft IOC v2.9 michael.abbott
