1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Please help with "caput -c"
To: "Zhang, Dehong" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Mar 2015 19:01:12 +0000
Hi Dehong,
I don't understand.  All the EPICS records I've used behave correctly when written to by a ca_put_callback, whether they use synchronous or asynchronous device support.  Are you writing a new record type, or trying to get asynchronous device support to work with an existing record type, or what?
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Zhang, Dehong [[email protected]]
Sent: Wednesday, March 11, 2015 1:48 PM
To: [email protected]
Subject: Please help with "caput -c"
Hi Friends,
I am trying to implement an asynchronous record, would like to support
this "put callback" feature.  From the documentation, it seems I have to do
the following:
1. set "pp(TRUE)" for the field the user is going to "caput"
2. make sure only call "recGblFwdLink" (within "process") when the action is
    finished, or use a BUSY record in the end of the FLNK chain such that it
    is "DONE" only when the action is finished.  -- during this process the PACT
    field of the original record can go up and down.
I have been playing with all these combinations, and by adding "-w **" after
the "caput -c", am getting inconsistent and unreliable results -- it either does
not work - calls back immediately, or waits unnecessarily long then calls back.
It rarely calls back right after the original record finishes processing and declares
the action is finished.  Guess I missed something.  Please spare a few moments
and advice on what exactly I need to do.
(We use 3.14.12-0.4.0, on linux machines).
Thank you very much, Best regards,
Dehong
Re: Please help with "caput -c" Benjamin Franksen
Please help with "caput -c" Zhang, Dehong
Prev: Please help with "caput -c" Zhang, Dehong
Next: Re: Please help with "caput -c" Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
