Hi Martin, let me explain you some issues concerning your doubts. Several years ago I modified the open source ptp for Linux version, to be used with RTEMS into an specific board with a coldfire V2 and an specific PHY that permits hardware timestamps compliant with PTP v1 and V2. So, it is possible to use PTP with RTEMS. Depending which clock source you want for synchronizing the ptp, you should modify the PTP src code accordingly to do it. About PTP for EPICS, I suppose you mean EPICS for RTEMS, I don't know if it is implemented. To do it, a lot of options could be done, but to do it independently of the hardware architecture (and without hardware timestamping), it should be interesting to implement an EPICS device support for it. Regards! Diego 2015-03-12 18:16 GMT+01:00 Konrad, Martin <[email protected]>: Hi,
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
