1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: related to PLC driver
Date: Tue, 17 Mar 2015 17:56:27 -0300
I think you need to put this in a "support" directory.
If you don't have one already, create a new directory (call it something like "support"), then change to that directory and run 'makeBaseApp.pl -t support'
You will then find a configure directory and a Makefile. Unzip the s7plc stuff in the new support directory. s7plc will be in a subdirectory.
On 03/17/2015 01:33 AM, priya tiwari wrote:
Hello sir,
I have downloaded the driver package s7plc.tgz
<http://epics.web.psi.ch/software/s7plc/s7plc.tgz> from PSI for
communicating with Siemens S7 plc 300,but How to use it?
                    When I make this then got the error there is no
configuration or rule.What is a solution of this problem?
           Thanks
Mike Westfall
Gemini Observatory
Colina El Pino S/N, Casilla 603
La Serena, Chile
Tel: +56 51 2205625
related to PLC driver priya tiwari
Prev: RE: Problem with HDF5 plugin for areaDetector Mark Rivers
Next: Text input to char waveform - bug? Isabella Rey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: related to PLC driver priya tiwari
