1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Text input to char waveform - bug?
To: Isabella Rey <[email protected]>
Cc: [email protected]
Date: Wed, 18 Mar 2015 14:39:16 +0100
Hi Isabella,
it does not work for me, too - but I’m using CSS 3.2.16 on Mac OS. Funny how it works for you on Linux..
What works for me is setting the PV text value using Probe View (not really a production solution).
Best regards,
Hinko
> On 18 Mar 2015, at 13:12, Isabella Rey <[email protected]> wrote:
> Hi All,
> I'm running CSS 3.2.16 in Windows.
> I have a BOY text input widget that I want to use to write to a waveform of char, called TEST.
> The waveform is empty at startup.
> If I type something in the text input, like "abc", I get the following error message in the BOY Console:
> 2015-03-18 12:04:37 ERROR: Failed to write value to PV TEST from widget Text Input_1.
> Illegal input : abc
> java.lang.ArrayIndexOutOfBoundsException: 0
> If the waveform is not empty, the string gets updated correctly and there is no error.
> If I do the same in CSS in my Linux VM, all works fine, even at startup.
> Is this a bug in the Windows version or am I missing something?
> Thanks,
> Isabella
Re: Text input to char waveform - bug? Isabella Rey
Prev: Re: CSS - how to read waveform of CHARS (or STRINGS) in a script? - SOLVED Isabella Rey
Next: Increment array counter for NDFileModeSingle Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Text input to char waveform - bug? Isabella Rey
Next: Re: Text input to char waveform - bug? Isabella Rey
