1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: adding devIocStats support to motor IOCs
Date: Fri, 20 Mar 2015 23:42:11 -0400
Hello tech-talkers,
I am having problems adding devIocStat support to asyn motor IOCS.I get the the following two errors when I run st.cmd:
when records are being loaded from iocAdminSoft.db this is the errror I keep getting:
Can't set "TEST:CA_CLNT_CNT.DTYP" to "IOC stats"
and after iocInit the following error:
Subroutine not found PV: TEST:SYSRESET recSub(init_record)
PV: TEST:CA_CLNT_CNT scanAdd: I/O Intr not valid (no get_ioint_info)
May be I am missing something.
I am using motor-6-8 and devIocStats-3-1-7 .
Any help is appreciated.
Thank you
Ali
Alireza Panna
University of Maryland, College Park
RE: adding devIocStats support to motor IOCs Mooney, Tim M.
Prev: Registration Open for the Spring 2015 EPICS Collaboration Meeting Spring 2015 EPICS Collaboration Meeting
Next: RE: adding devIocStats support to motor IOCs Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Registration Open for the Spring 2015 EPICS Collaboration Meeting Williams Jr., Ernest L.
