1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Strange StreamDev behaviour
To: <[email protected]>, <[email protected]>
Date: Tue, 24 Mar 2015 10:35:29 +0000
This protocol looks familiar, we have written a driver for the N1470 series of NIM HV power supplies here:
http://controls.diamond.ac.uk/downloads/support/caenN1470/
Streamdevice definitely supports more that one parameter as we use it like that:
record(ao, "$(P)$(Q):VSET$(CHAN)") {
  field(DESC, "HV Setpoint")
  field(DTYP, "stream")
  field(FLNK, "$(P)$(Q):VSET$(CHAN):RBV")
  field(OUT, "@caenN1470.proto writechan($(ADDR),$(CHAN),VSET,$(P)$(Q)) $(PORT)")
  field(PREC, "1")
  field(EGU, "V")
  field(DRVH, "8000")
  field(DRVL, "0")
  field(PINI, "YES")
  field(SDIS, "$(P)$(Q):DISABLE")
And in the protocol file:
readchan { out "$BD:\$1,CMD:MON,CH:\$2,PAR:\$3"; in "#BD:%*d,CMD:OK,VAL:%f"; }
Do you have all your macros defined when you instantiate the template file?
Tom Cobb
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Jörn Wüstenfeld
> Sent: 24 March 2015 10:25
> To: [email protected]
> Subject: Strange StreamDev behaviour
> Hello,
> I currently have a problem with Streamdev version 2.6 and asyn 2.26
> using base
> 3.14.12.4 on an arm linux.
> I have a protocol that needs two parameters:
> monIMdec {
> 	out "$BD:\$1,CMD:MON,CH:\$2,PAR:IMDEC";
> 	in  "#BD:%*i,CMD:OK,VAL:%i";
> The corresponding database file contains the following record using
> this
> protocol:
> record (ai, "xxx:monIMdec")
> 	field (DESC, "readback of current resolution")
> 	field (DTYP,  "stream")
> 	field (INP,  "@CaenHVNimUsb.proto monIMdec($(ps), $(channel))
> $(interface)")
>   field (PREC, "2")
> Running the IOC I get the following error message during the
> initializaion
> phase:
> _main_ Businterface '0)' not found for 'xxx:monIMdec'
>  _main_ xxx:monIMdec: Can't attach to bus 0) -1
>  _main_ xxx:monIMdec: Record initialization failed
> If I do a "dbpr xxx:monIMdec", the value in the record is undefined.
> If I do a "dbtr xxx:monIMdec" and then a "dbpr xxx:monIMdec" the
> expected
> value is set. and no further messages are printed.
> It looks to me that during initialization the parser of StreamDev does
> not
> handle more than one protocol parameter.
> What can I do to get rid of this error messages?
> With kind regards,
> Jörn Wüstenfeld
Re: Strange StreamDev behaviour Jörn Wüstenfeld
Prev: Strange StreamDev behaviour Jörn Wüstenfeld
Next: Re: Strange StreamDev behaviour Jörn Wüstenfeld
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
