Hi Bernardo,
You can use an additional ao record to forward a value from one record
to another record's field.
If e.g. the ai "S7low" has the LOW threshold from your alarm poll group,
and the ai "S7val" has the matching value, you can add:
record(ao, "S7low_fwd") {
field(OMSL, "closed_loop")
field(DOL, "S7low CP")
field(OUT, "S7val.LOW")
That would push the value of "S7low" into the LOW field of "S7val"
whenever "S7low" changes.
~Ralph
On 27/03/2015 13:17, Bernardo Carvalho wrote:
Dear All,
I'm using EPICS with a s7-1200 PLC from Siemens that uses separate
"tags" for values and alarms that are transferred periodically
to the IOC (using s7nodave and "Poll Groups").
Is it possible to use a FLNK link to change Alarm related fields
(HIHI, HIGH, LOW, and LOLO ) on a "ai" PV?
Should I use subroutines or any other method?
Thanks in advance
-Bernardo
- FLNK + Alarm Fields Bernardo Carvalho
Re: FLNK + Alarm Fields Ralph Lange
Recent encrypted mails to tech-talk Ralph Lange
<2015>
2025
2026
<2015>
2025
2026
