Dear Paul,
Thanks for the comment to transferArray.
> field(OUT,DBF_INLINK)
This is because, once, we need to copy all components of output waveform
into the VAL field of transferArray.
And we modify them with information from input waveform.
Then, finally, they are re-stored into output waveform again.
This is the real process of transferArray.
For the first step, when we copy from output waveform, we use get_link.
That's why here is "DBF_INLINK" but not "DBF_OUTLINK".
Could you try to process without the modification you suggest?
I think it works without any problem.
However please tell me if you find some problem related this.
Cheers,
Hiroshi.
----- Original Message -----
> Hiroshi,
> Your recent transferArray record was just what I needed for a recent
> application, thank you for making it available. In the .dbd file:
> field(OUT,DBF_INLINK) should be
> field(OUT,DBF_OUTLINK)
> This is used by visual DB editors.
> -ps
> Subject: The transferArray record
> From: <[email protected]>
> To: <[email protected]>
> Cc: [email protected]
> Date: Wed, 01 Oct 2014 19:31:50 +0900
> Dear EPICS colleagues,
> Here I would like to introduce the new record which is developed at
KEK.
> The "transferArray" record copies a part of waveform elements and
pastes
> them into the other waveform.
> It is developed for a specific use for KEK accelerator, especially,
> LINAC.
> However, I believe it can be used for the various purposes.
> We prepared source and manual on our web so that you can easily
utilize.
> http://www-linac.kek.jp/cont/epics/transferarray/
> I hope it helps you.
> Please have a look and use in your work.
> Also please ask us anything about this record.
> Best regards,
> Hiroshi Kaji,
> KEK Accelerator Control Group.
- transferArray Record dbd error? Paul Sichta
EDM Widget in epicsQt Richa Devon
<2015>
2025
2026
<2015>
2025
2026
