1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mbbo ENUM record
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 30 Mar 2015 12:50:16 +0200
Hi Amien,
One single mbbo record should do the job.
Configured quite like your rangeStr, but with PINI, DTYP and OUT from range.
Cheers,
~Ralph
On 30/03/2015 12:21, Amien Crombie [TLABS] wrote:
I have a BOY "Choice Button" with its PV set to "$(dev):RangeStr"
My 'range' PV is between 1 and 8 with a corresponding ENUM string of 8 also.
The widget works fine in that it sets the 'range' on selecting the ENUM
but when I do
a write to the 'range' from elsewhere, the 'range' is set to the value
but my ENUM widget it not.
I then added the '$(dev):RangeENUM' record so that whenever a
'$(dev):range' is done, a FLNK updates my widget as well.
This works as I would want it to be I'm sure there is a better way (not
having 2 mbbo records ie).
   record(ao,         "$(dev):range")  {
      field(DTYP,   "asynInt32")
      field(PINI,   "YES")
      field(OUT,    "@asyn(int32 $(addr) 1.0) reason(2)")
      field(FLNK,   "$(dev):RangeENUM PP")
   ##  ENUMS for 8 Ranges #####################################
   record(mbbo, "$(dev):RangeStr") {
      field(DTYP, "Soft Channel")
      field(OUT,  "$(dev):range PP")
      field(ONVL, "1")
      field(TWVL, "2")
      field(THVL, "3")
      field(FRVL, "4")
      field(FVVL, "5")
      field(SXVL, "6")
      field(SVVL, "7")
      field(EIVL, "8")
      field(ONST, " 1  :  10 mA")
      field(TWST, " 2  :   1 mA")
      field(THST, " 3  : 100 uA")
      field(FRST, " 4  :  10 uA")
      field(FVST, " 5  :   1 uA")
      field(SXST, " 6  : 100 nA")
      field(SVST, " 7  :  10 nA")
      field(EIST, " 8  :   1 nA")
   record(mbbo, "$(dev):RangeENUM") {
      field(OMSL, "closed_loop")
      field(DOL,  "$(dev):range")
      field(OUT,  "$(dev):RangeStr PP")
      field(ONVL, "1")
      field(TWVL, "2")
      field(THVL, "3")
      field(FRVL, "4")
      field(FVVL, "5")
      field(SXVL, "6")
      field(SVVL, "7")
      field(EIVL, "8")
Thanks
Amien
mbbo ENUM record Amien Crombie [TLABS]
Prev: mbbo ENUM record Amien Crombie [TLABS]
Next: RE: EDM Widget in epicsQt Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: support for DTM-151? Michael Davidsaver
