1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM Widget in epicsQt
To: Emmanuel Mayssat <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Tue, 31 Mar 2015 10:05:39 +0530
Hi Emmanuel,
Thanks for the update. I was actually looking for a widget available in EDM which provides a visual keypad to enter numbers in a text field. Due to its absence in epicsQt, i'll form one myself.
R.Devon
On Tue, Mar 31, 2015 at 12:44 AM, Emmanuel Mayssat <[email protected]> wrote:
Devon,
No sure I understand your questions. Could you be more specific?
Based on what I understand, to answer your questions, I would just say that an EDM to Qt conversion tool is in progress.
When you mention to the numeric key pad are you referring to the tablet version?
Emmanuel Mayssat
http://www.epicsqt.org
Date: Mon, 30 Mar 2015 12:22:26 +0530
Subject: EDM Widget in epicsQt
To: [email protected]
Greetings,
Is there a way to use an EDM widget in epicsQt for PV control?
Alternatively, is there a provision for numeric key pad in epicsQt?
R. Devon
EDM Widget in epicsQt Richa Devon
RE: EDM Widget in epicsQt Emmanuel Mayssat
Prev: RE: support for DTM-151? Allison, Stephanie
Next: IOC implementation by JAVA/Python Tong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EDM Widget in epicsQt Emmanuel Mayssat
Next: mbbo ENUM record Amien Crombie [TLABS]
