1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: data of modbus write function didn't updated automatically
To: [email protected]
Date: Thu, 2 Apr 2015 14:15:25 +0900
Hi, all
for communication with PLC via using modbus, I used modbusR2-5 version.
i found one problem.
here is 4 functions that InFunction A,B and OutFunctions C, D.
they access same memory.
After I changed memory data via using OutFunction C or D,
data of InFunctions A, B updated automatically (this is written on manual),
but data of OutFunctions C, D didn't updated automatically.
I wonder if it is possible to update data of the other OutFunctions automatically.
below is my log data.
[sjr@localhost ~]$ caget CIS:TRANS1:YWIn1
CIS:TRANS1:YWIn1 0
[sjr@localhost ~]$ caget CIS:TRANS1:YWOut1
CIS:TRANS1:YWOut1 0
[sjr@localhost ~]$ caget CIS:TRANS1:YBIn1_1
CIS:TRANS1:YBIn1_1 Low
[sjr@localhost ~]$ caget CIS:TRANS1:YBOut1_1
CIS:TRANS1:YBOut1_1 Low
[sjr@localhost ~]$ caput CIS:TRANS1:YBOut1_1 1
Old : CIS:TRANS1:YBOut1_1 Low
New : CIS:TRANS1:YBOut1_1 High
CIS:TRANS1:YBIn1_1 High
CIS:TRANS1:YWIn1 2
CIS:TRANS1:YWOut1 0
[sjr@localhost ~]$ caput CIS:TRANS1:YWOut1 0
Old : CIS:TRANS1:YWOut1 0
New : CIS:TRANS1:YWOut1 0
CIS:TRANS1:YWIn1 0
[sjr@localhost ~]$
and this is substitutions.
# These are the Yn inputs done with bit access Y0-Y7
file "../../db/bi_bit.template" { pattern
{P,           R,         PORT,             OFFSET,   ZNAM,   ONAM,  ZSV,       OSV,    SCAN}
{CIS:TRANS1:,    YBIn1_0,   T1_Yn_In_Bit,   0x10,    Low,    High,  NO_ALARM,  MAJOR,  "I/O Intr"}
{CIS:TRANS1:,    YBIn1_1,   T1_Yn_In_Bit,   0x11,    Low,    High,  NO_ALARM,  MAJOR,  "I/O Intr"}
file "../../db/intarray_in.template" { pattern
{P,           R,           PORT,             NELM,     SCAN}
{CIS:TRANS1:,    YBIn0Array,  T1_Yn_In_Bit,     32,     "I/O Intr"}
file "../../db/asynRecord.template" { pattern
{P,           R,         PORT,             ADDR,     TMOD,  IFACE}
{CIS:TRANS1:,    YBIn0Asyn, T1_Yn_In_Bit,     0,        Read,  asynUInt32Digital}
file "../../db/statistics.template" { pattern
{P,           R,         PORT,          SCAN}
{CIS:TRANS1:,    YBIn0St,     T1_Yn_In_Bit,  "10 second"}
file "../../db/poll_delay.template" { pattern
{P,           R,              PORT}
{CIS:TRANS1:,    YBIn0PollDelay, T1_Yn_In_Bit}
file "../../db/mbbiDirect.template" { pattern
{P,           R,       PORT,         OFFSET,    MASK,  SCAN}
{CIS:TRANS1:,    YWIn0,     T1_Yn_In_Word,     0x0,        0xFFFF, "I/O Intr"}
{CIS:TRANS1:,    YWIn1,     T1_Yn_In_Word,     0x1,        0xFFFF, "I/O Intr"}
{CIS:TRANS1:,    YWIn0Array, T1_Yn_In_Word,     80,     "I/O Intr"}
{CIS:TRANS1:,    YWIn0Asyn, T1_Yn_In_Word,    0,        Read,  asynInt32}
{P,           R,       PORT,       SCAN}
{CIS:TRANS1:,    YWIn0St,     T1_Yn_In_Word, "10 second"}
{P,           R,            PORT}
{CIS:TRANS1:,    YWIn0PollDelay, T1_Yn_In_Word}
# These are the Yn outputs done with bit access.  Y0-Y7
file "../../db/bo_bit.template" { pattern
{P,           R,          PORT,              OFFSET,   ZNAM,   ONAM}
{CIS:TRANS1:,    YBOut1_0,   T1_Yn_Out_Bit,   0x10,    Low,    High}
{CIS:TRANS1:,    YBOut1_1,   T1_Yn_Out_Bit,   0x11,    Low,    High}
{CIS:TRANS1:,    YBOut0Asyn, T1_Yn_Out_Bit,     0,        Read,  asynUInt32Digital}
{P,           R,          PORT,           SCAN}
{CIS:TRANS1:,    YBOut0,     T1_Yn_Out_Bit,  "10 second"}
{P,           R,            PORT}
{CIS:TRANS1:,    YBOut0PollDelay, T1_Yn_Out_Bit}
file "../../db/mbboDirect.template" { pattern
{CIS:TRANS1:,    YWOut0,     T1_Yn_Out_Word,     0x0,        0xFFFF, "I/O Intr"}
{CIS:TRANS1:,    YWOut1,     T1_Yn_Out_Word,     0x1,        0xFFFF, "I/O Intr"}
{CIS:TRANS1:,    YWOut0Asyn, T1_Yn_Out_Word,    0,        Read,  asynInt32}
{P,           R,       PORT,       SCAN}
{CIS:TRANS1:,    YWOut0St,     T1_Yn_Out_Word, "10 second"}
{P,           R,            PORT}
{CIS:TRANS1:,    YWOut0PollDelay, T1_Yn_Out_Word}
and this is st.cmd files
drvAsynIPPortConfigure("Trans1","192.168.1.10:502",0,0,1)
modbusInterposeConfig("Trans1",0,5000,0)
# Read 32 bits.  Function code=1.
drvModbusAsynConfigure("T1_Yn_In_Bit",   "Trans1", 0, 1,  17600, 040,    0,  100, "LSIS_PLC")
# Write 32 bits.  Function code=5.
drvModbusAsynConfigure("T1_Yn_Out_Bit",  "Trans1", 0, 5,  17600, 040,    0,  100, "LSIS_PLC")
# Read 80 words (128 bits).  Function code=3.
drvModbusAsynConfigure("T1_Yn_In_Word",  "Trans1", 0, 3, 1100, 80,    0,  100, "LSIS_PLC")
# Write 80 words (128 bits).  Function code=6.
drvModbusAsynConfigure("T1_Yn_Out_Word", "Trans1", 0, 6, 1100, 80,    0,  100, "LSIS_PLC")
and this is my epics environment.
epics> epicsParamShow
EPICS_AR_PORT: 7002
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_ADDR_LIST: 100.100.10.255 192.168.1.255 10.10.10.255
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_MAX_ARRAY_BYTES: 1000000000
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CMD_PROTO_PORT is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_TIMEZONE: CUS::360:031302:110602
EPICS_TS_NTP_INET is undefined
IOCSH_HISTSIZE: 50
IOCSH_PS1: epics>
Best Regards,
JaeRyong
RE: data of modbus write function didn't updated automatically Mark Rivers
Prev: RE: Stream device problem with redirection in @mismatch Mazanec Tomáš
Next: Re: STAT=SCAN recover Isabella Rey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS UIs in the context of changing enum record identifiers Jameson Graef Rollins
Next: RE: data of modbus write function didn't updated automatically Mark Rivers
