1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: aravisGigEApp and glib
Date: Tue, 7 Apr 2015 13:39:07 +0000
I’m trying to use aravisGigEApp on a RHEL7 linux system to display and capture video images. When I run “make” in aravisGigEApp/src, I get an error which looks like I’m missing libglib-2.0.a (see below). I have /usr/lib64/libglib-2.0.so, but I seem to need the glib2-static package, which is not available for RHEL7. Is there a fix for this, or should I fall back to RHEL6?
[root@video src]# make
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[1]: Entering directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
make[1]: *** No rule to make target `../../../lib/linux-x86_64/libglib-2.0.a', needed by `libaravisCamera.so'.  Stop.
make[1]: Leaving directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
[root@video src]#
Eliot Specht                        Voice: (865)574-7682
Oak Ridge National Laboratory       FAX:   (865)574-4913
P.O. Box 2008, MS 6064
Oak Ridge, TN 37831-6064
RE: aravisGigEApp and glib Mazanec Tomáš
Prev: RE: Stream device problem with redirection in @mismatch ruzickaj
Next: Re: MTCA.4 board with IO modules Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Program Available for the Spring 2015 EPICS Collaboration Meeting Spring 2015 EPICS Collaboration Meeting
Next: RE: aravisGigEApp and glib Mazanec Tomáš
