1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreaDevice formating problem
To: Jörn Wüstenfeld <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Wed, 8 Apr 2015 15:48:55 +0000
According to man sscanf, %d might work - it matches a decimal integer - whereas
%i matches decimal, octal or hexadecimal.
> On Apr 8, 2015, at 5:30 AM, Jörn Wüstenfeld <[email protected]> wrote:
> Hello,
> I have a problem with a device, which returns a value with a fixed length of 3
> characters, left padded with zero. If the value is below 100, it is
> interpreted as an octal value by StreamDevice if I use %i as format. Of course
> I can use %s and a stringin record, but then I do not have the EGU fioeld
> available for displaying.
> Is there a way to handle this in StreamDevice? Or is my only chance to write
> my own asyn driver for this device?
> Regards
> Jörn Wüstenfeld
Re: StreaDevice formating problem Jörn Wüstenfeld
Prev: Re: StreaDevice formating problem Dirk Zimoch
Next: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: StreaDevice formating problem Jörn Wüstenfeld
