1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits
To: Heinz Junkes <[email protected]>, "[email protected] ([email protected])" <[email protected]>
Date: Wed, 8 Apr 2015 16:37:36 -0500
Hi Heinz,
On 04/08/2015 02:34 PM, Heinz Junkes wrote:
> is there an easy way to prevent the clipping within limits (DRVH,
> DVL) in the analog output record (softChannel).
> I would like to simply ignore a value that lies outside the limits
> without using an addtional record (e.g. calcout) to check the value
> beforehand.
You could configure the HIHI and/or LOLO alarm limit to the DRVH/DRVL
value with HHSV/LLSV set to Invalid severity, then set the IVOA field to
tell the record to not drive the outputs on invalid severity. That's
about the only possibility you have within the record itself though.
HTH,
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Heinz Junkes
Prev: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Heinz Junkes
Next: Re: StreaDevice formating problem Jörn Wüstenfeld
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: caQtDM 3.9.1 Release Brands Helge (PSI)
