Hi Gennaro,
Here is an example of how I've done what you are asking with longout and longin records. The same scheme will work with a bo and bi records.
The input _RBV record gets processed when the value changes, and it updates the soft output record without processing the asyn output record.
record(longout, "$(P)$(R)FileNumber")
field(PINI, "YES")
field(OUT, "$(P)$(R)FileNumber_write PP")
field(VAL, "1")
record(longout, "$(P)$(R)FileNumber_write")
field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
field(DISV, "1")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
record(longin, "$(P)$(R)FileNumber_RBV")
field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
field(SCAN, "I/O Intr")
field(FLNK, "$(P)$(R)FileNumber_Sync")
record(longout, "$(P)$(R)FileNumber_Sync")
field(DOL, "$(P)$(R)FileNumber_RBV NPP")
field(OMSL, "closed_loop")
field(OUT, "$(P)$(R)FileNumber PP")
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, April 14, 2015 10:12 AM
To: [email protected]
Subject: binary output record
I'm developing an EPICS IOC and I'm facing with following problem:
IOC has the following binary output (bo) record:
record(bo,"gpio01") {
field(DTYP,"GPIO control")
field(DESC,"GPIO line 1")
field(SCAN,"Passive")
I'm able to drive the bo (on/off) but in this application it is possible
to drive the GPIO externally (outside EPICS IOC) and I want bo record to
get the status of pin (e.g. by a binary input) in order to avoid
out-of-sync;
is it possible to receive an example configuration of bo/bi record to
accomplish this ?
Thanks in advance,
Gennaro
Gennaro Tortone
INFN Napoli
Italy
tel: +39 81 676169
"Computer Science is no more about computers
than astronomy is about telescopes."
- Edsger Dijkstra
- binary output record [email protected]
power supply question Sinclair, John William
Re: Problems using static database routines to modify IOCs Dirk Zimoch
<2015>
2025
2026
<2015>
2025
2026
