I apologize my original message had 2 typos, it should be:
The next sequence you collect will be:
/home/me/test2_00000.tif
/home/me/test2_00001.tif
/home/me/test2_00009.tif
The "2" in this case is the FileNumber, and comes from the areaDetector driver. The 00000, 00001, etc. come from camserver.
Sent: Thursday, April 16, 2015 10:49 PM
To: GONG Yu; EPICS_tech_talk
Subject: RE: Help-areaDetector used for Pilatus
Hi GongYu,
> **question1: epicsEnvSet("QSIZE", "20")
> what does QSIZE mean? What number should I set to it or just using default 20?
It is the size of the input queue for the plugins. 20 is probably fine unless you are collecting bursts of data faster than your file saving plugin can write, and then a larger queue can be useful.
> **question2: epicsEnvSet("NCHANS", "2048")
> what does NCHANS mean? What number should I set to it or just using default 2048?
It is the number of time series points used for the statistics plugins. 2048 is probably fine.
Note that in ADPilatus R2-1, which was released earlier today, I have added comments to each of those lines to help explain what those environment variables do. This is from the new st.cmd example file:
# Prefix for all records
epicsEnvSet("PREFIX", "13PIL1:")
# The port name for the detector
epicsEnvSet("PORT", "PIL")
# The queue size for all plugins
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE", "487")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE", "195")
# The maximum number of time series points in the NDPluginStats plugin
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
< **question3: when I exposure single image, namely the parameters [# Images] 1, [Auto increment] Yes,
> I press [start] the [Next file #] (shown in blue color beside the box) is auto incremented which is as I expected;
> But if I set [#Images] 10 and [Auto increment] Yes to exposure multy images,
> after I press [start], the numbers followed the file name in name of image files are correct (such as from 000 to 009),
> but the [Next file#] (shown in blue color beside the box) is auto incremented only once (such as from 000 to 001,
> but not incremented anymore). Is this situation abnormal ?
That is normal. The ADPilatus documentation here explains it, look in table entry for NDFileTemplate here:
http://cars.uchicago.edu/software/epics/pilatusDoc.html
The FileNumber record is incremented once for each acquisition "sequence". Within a sequence camserver itself numbers the files, using its own rules that are explained the pilatusDoc.html. If you set the following:
FilePath="/home/me/"
FileName="test"
FileNumber=1
FileTemplate="%s%s%d_.tif"
AutoIncrement=Yes
then when you collect a sequence of 10 images camserver will create files
/home/me/test1_00000.tif
/home/me/test1_00001.tif
/home/me/test1_00009.tif
/home/me/test3_00001.tif
/home/me/test3_00009.tif
It is a very good idea to have your file template end in "_.tif", because that trailing underscore has special meaning for camserver. It will put its numbers after that underscore. If you don't use the underscore it can be quite confusing, because it will start its sequence with the FileNumber and then the AutoIncrement may even cause files to be overwritten.
From: [email protected] [[email protected]] on behalf of GONG Yu [[email protected]]
Sent: Thursday, April 16, 2015 9:49 PM
To: EPICS_tech_talk
Subject: Help-areaDetector used for Pilatus
Hello everyone,
Recently I use areaDetector to control pilatus3 detector, but I am not sure if the parameters in st.cmd were set correctly. In st.cmd scripts,
in areaDetector.adl main screen, I also have a problem:
**question3: when I exposure single image, namely the parameters [# Images] 1, [Auto increment] Yes, I press [sta rt] the [Next file #] (shown in blue color beside the box) is auto incremented which is as I expected; But if I set [#Images] 10 and [Auto increment] Yes to exposure multy images, after I press [start], the numbers followed the file name in name of image files are correct (such as from 000 to 009), but the [Next file#] (shown in blue color beside the box) is auto incremented only once (such as from 000 to 001, but not incremented anymore). Is this situation abnormal ?
**Some parameters related to Pilatus3 is as below
number of modules 3x8=24
pixel size 172x172 μm^2
format 1475x1679=2476525 pixels
Dynamic range 20 Bits (0: 1048573)
Counter overflow state 1048573
readout time 0.95 ms
Framming rate 250 Hz
(camserver is in a computer with IP 10.10.10.100, areaDetector is in another computer with IP 10.10.10.10.)
**The contents in st.cmd are listed below
< envPaths
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/pilatusDetectorApp.dbd")
pilatusDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("XSIZE", "1475")
epicsEnvSet("YSIZE", "1679")
# Create the asyn port to talk to the Pilatus on port 41234.
drvAsynIPPortConfigure("camserver","10.10.10.100:41234")
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
asynOctetSetOutputEos("camserver", 0, "\n")
pilatusDetectorConfig("$(PORT)", "camserver", $(XSIZE), $(YSIZE), 0, 0)
dbLoadRecords("$(ADCORE)/db/ADBase.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(ADCORE)/db/NDFile.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(ADPILATUS)/db/pilatus.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "$(PORT)", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDPluginBase.template","P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=0")
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=2476525")
# Load all other plugins using commonPlugins.cmd
< $(ADCORE)/iocBoot/commonPlugins.cmd
set_requestfile_path("$(ADPILATUS)/pilatusApp/Db")
#asynSetTraceMask("$(PORT)",0,255)
#asynSetTraceMask("$(PORT)",0,3)
iocInit()
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=$(PREFIX)")
I hope someone could help me. Thank you!
GongYu
- Help-areaDetector used for Pilatus GONG Yu
- RE: Help-areaDetector used for Pilatus Mark Rivers
RE: Gentec S-link power meter problem with ending I/O interrupt measurement bohmm
Re: Re: iocStats reboot question Silver
<2015>
2025
2026
<2015>
2025
2026
