1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM properties dialog issue
To: EPICS Tech-Talk <[email protected]>
Date: Sat, 18 Apr 2015 08:39:42 +0200
Hi Mike,
You are aware, I suppose, that there are Debian packages for EPICS and a good set of extensions, including edm. [1]
What are your reasons for building from source?
Cheers,
~Ralph
[1] http://epics.nsls2.bnl.gov/debian/
On 18/04/2015 02:31, Mesa Mike wrote:
Was finally able to build EDM for my Debian 64-bit system, but there is a rendering issue that I can't figure out.
For instance, the text labels are cut off on the left in property dialog boxes.
For an example, see http://mesamike.org/edmwidget.png
If you've seen this and were able to fix it, let me know how...
Mike Westfall
Gemini Observatory
Re: EDM properties dialog issue Mike Westfall
EDM properties dialog issue Mesa Mike
Prev: Re: Installing EPICS... error Johnson, Andrew N.
Next: Re: Installing EPICS... error Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM properties dialog issue Mesa Mike
Next: Re: EDM properties dialog issue Mike Westfall
