Hi John,
Sorry for all of your troubles on this.
The problems that you bumped into have been resolved on the head of the epicsqt SVN Repo:
svn checkout svn://svn.code.sf.net/p/epicsqt/code/trunk
Please, have a look.
I believe Andrew will be cutting a new release soon.
Cheers,
Ernest
Sent: Monday, April 20, 2015 8:13 AM
To: Williams Jr., Ernest L.; [email protected]
Subject: Re: epicsQt and QWT6
More detail and what I found:
Our linux boxes have Qt 4.8.5 installed.
I installed Qwt 5.2.3 , but I don't have admin privileges so it is not a completely normal installation.
I downloaded epicsqt-3.0.2-src.tar.gz and built it against Qwt 5.2.3 and that worked.
I then installed Qwt 6.0.1 and tried to build epicsqt-3.0.2 against that but it didn't work, failed to link because it didn't find libqwt. Make output is shown below. All this was last Friday.
So this morning I deleted my epicsqt folder and started over and found I got the same error with Qwt 5.2.3 and Qwt 6.0.1 Don't know why it worked last week.
QWT_INCLUDE_PATH =/nfs/erl/erp/tmp/jad/qtdev/qwt-6.0.1/include or /nfs/erl/erp/tmp/jad/qtdev/qwt-5.2.3/include as appropriate.
LD_LIBRARY_PATH is also points to the in use Qwt version library, e.g.
/nfs/erl/erp/tmp/jad/qtdev/epicsqt/framework/designer:/nfs/erl/erp/tmp/jad/qtdev/qwt-6.0.1/lib
I then changed
epicsqt/framework/framework.pro to give the location of the Qwt library, i.e. changed
unix {
LIBS += -lqwt
to
unix {
LIBS += -lqwt -L/nfs/erl/erp/tmp/jad/qtdev/qwt-6.0.1/lib
and it now builds. I can change 6.0.1 to 5.2.3 and it also builds.
(Note: I am new to Qt so don't hesitate to offer correction)
John Dobbins
g++ -Wl,-O1 -Wl,-rpath,/nfs/opt/qt-4.8.5/lib -shared -o libQEPlugin.so O.linux-x86_64/obj/QEEnvironmentVariables.o O.linux-x86_64/obj/QEOptions.o O.linux-x86_64/obj/QESettings.o O.linux-x86_64/obj/QEAdaptationParameters.o O.linux-x86_64/obj/QEActionRequests.o O.linux-x86_64/obj/QEAxisPainter.o O.linux-x86_64/obj/QECommon.o O.linux-x86_64/obj/QEDialog.o O.linux-x86_64/obj/QEDelayedText.o O.linux-x86_64/obj/QEDisplayRanges.o O.linux-x86_64/obj/QEExpressionEvaluation.o O.linux-x86_64/obj/QEFileMonitor.o O.linux-x86_64/obj/QEFixedPointRadix.o O.linux-x86_64/obj/QEFrameworkVersion.o O.linux-x86_64/obj/QEPvNameSearch.o O.linux-x86_64/obj/QEPVNameSelectDialog.o O.linux-x86_64/obj/QEGraphic.o O.linux-x86_64/obj/QEGraphicMarkup.o O.linux-x86_64/obj/QEPlatform.o O.linux-x86_64/obj/QEScaling.o O.linux-x86_64/obj/QEScanTimers.o O.linux-x86_64/obj/PasswordDialog.o O.linux-x86_64/obj/windowCustomisation.o O.linux-x86_64/obj/macroSubstitution.o O.linux-x86_64/obj/Generic.o O.linux-x86_64/o!
bj/CaRecord.o O.linux-x86_64/obj/CaObject.o O.linux-x86_64/obj/CaConnection.o O.linux-x86_64/obj/CaRef.o O.linux-x86_64/obj/QCaAlarmInfo.o O.linux-x86_64/obj/QCaConnectionInfo.o O.linux-x86_64/obj/QCaDataPoint.o O.linux-x86_64/obj/QCaDateTime.o O.linux-x86_64/obj/QCaEventFilter.o O.linux-x86_64/obj/QCaEventUpdate.o O.linux-x86_64/obj/QCaObject.o O.linux-x86_64/obj/QCaStateMachine.o O.linux-x86_64/obj/QCaVariableNamePropertyManager.o O.linux-x86_64/obj/QEByteArray.o O.linux-x86_64/obj/QEFloating.o O.linux-x86_64/obj/QEFloatingArray.o O.linux-x86_64/obj/QEFloatingFormatting.o O.linux-x86_64/obj/QEInteger.o O.linux-x86_64/obj/QEIntegerArray.o O.linux-x86_64/obj/QEIntegerFormatting.o O.linux-x86_64/obj/QELocalEnumeration.o O.linux-x86_64/obj/QEString.o O.linux-x86_64/obj/QEStringFormatting.o O.linux-x86_64/obj/qepicspv.o O.linux-x86_64/obj/maiaFault.o O.linux-x86_64/obj/maiaObject.o O.linux-x86_64/obj/maiaXmlRpcClient.o O.linux-x86_64/obj/QEArchiveInterface.o O.linux-x86_64/obj!
/QEArchiveManager.o O.linux-x86_64/obj/QEArchiveStatus.o O.lin!
ux-x86_64/obj/QEArchiveStatusManager.o O.linux-x86_64/obj/QEArchiveNameSearch.o O.linux-x86_64/obj/QEArchiveNameSearchManager.o O.linux-x86_64/obj/VariableNameManager.o O.linux-x86_64/obj/UserMessage.o O.linux-x86_64/obj/contextMenu.o O.linux-x86_64/obj/QEWidget.o O.linux-x86_64/obj/managePixmaps.o O.linux-x86_64/obj/QEDragDrop.o O.linux-x86_64/obj/styleManager.o O.linux-x86_64/obj/standardProperties.o O.linux-x86_64/obj/QEStringFormattingMethods.o O.linux-x86_64/obj/QEToolTip.o O.linux-x86_64/obj/QEDesignerPlugin.o O.linux-x86_64/obj/ContainerProfile.o O.linux-x86_64/obj/persistanceManager.o O.linux-x86_64/obj/applicationLauncher.o O.linux-x86_64/obj/QEAbstractWidget.o O.linux-x86_64/obj/QEAnalogIndicator.o O.linux-x86_64/obj/QEAnalogIndicatorManager.o O.linux-x86_64/obj/QEAnalogProgressBar.o O.linux-x86_64/obj/QEAnalogProgressBarManager.o O.linux-x86_64/obj/QBitStatus.o O.linux-x86_64/obj/QBitStatusManager.o O.linux-x86_64/obj/QEBitStatus.o O.linux-x86_64/obj/QEBitStatusM!
anager.o O.linux-x86_64/obj/QEGenericButton.o O.linux-x86_64/obj/QEPushButton.o O.linux-x86_64/obj/QERadioButton.o O.linux-x86_64/obj/QECheckBox.o O.linux-x86_64/obj/QEPushButtonManager.o O.linux-x86_64/obj/QERadioButtonManager.o O.linux-x86_64/obj/QECheckBoxManager.o O.linux-x86_64/obj/QEComboBox.o O.linux-x86_64/obj/QEComboBoxManager.o O.linux-x86_64/obj/QEConfiguredLayout.o O.linux-x86_64/obj/QEConfiguredLayoutManager.o O.linux-x86_64/obj/QEFileBrowser.o O.linux-x86_64/obj/QEFileBrowserManager.o O.linux-x86_64/obj/QEFileImage.o O.linux-x86_64/obj/QEFileImageManager.o O.linux-x86_64/obj/QEForm.o O.linux-x86_64/obj/QEFormManager.o O.linux-x86_64/obj/QEFormGrid.o O.linux-x86_64/obj/QEFormGridManager.o O.linux-x86_64/obj/QEFrame.o O.linux-x86_64/obj/QEFrameManager.o O.linux-x86_64/obj/QEGeneralEdit.o O.linux-x86_64/obj/QEGeneralEditManager.o O.linux-x86_64/obj/QEGroupBox.o O.linux-x86_64/obj/QEGroupBoxManager.o O.linux-x86_64/obj/QEHistogram.o O.linux-x86_64/obj/QEHistogramM!
anager.o O.linux-x86_64/obj/QEScalarHistogram.o O.linux-x86_64/obj/QESc!
alarHistogramManager.o O.linux-x86_64/obj/QEWaveformHistogram.o O.linux-x86_64/obj/QEWaveformHistogramManager.o O.linux-x86_64/obj/QEImage.o O.linux-x86_64/obj/QEImageManager.o O.linux-x86_64/obj/imageContextMenu.o O.linux-x86_64/obj/imageMarkup.o O.linux-x86_64/obj/videowidget.o O.linux-x86_64/obj/flipRotateMenu.o O.linux-x86_64/obj/profilePlot.o O.linux-x86_64/obj/selectMenu.o O.linux-x86_64/obj/zoomMenu.o O.linux-x86_64/obj/imageInfo.o O.linux-x86_64/obj/markupItem.o O.linux-x86_64/obj/markupBeam.o O.linux-x86_64/obj/markupHLine.o O.linux-x86_64/obj/markupVLine.o O.linux-x86_64/obj/markupLine.o O.linux-x86_64/obj/markupRegion.o O.linux-x86_64/obj/markupTarget.o O.linux-x86_64/obj/markupText.o O.linux-x86_64/obj/markupEllipse.o O.linux-x86_64/obj/brightnessContrast.o O.linux-x86_64/obj/QEImageOptionsDialog.o O.linux-x86_64/obj/QEImageMarkupThickness.o O.linux-x86_64/obj/fullScreenWindow.o O.linux-x86_64/obj/markupDisplayMenu.o O.linux-x86_64/obj/recording.o O.linux-x86_64!
/obj/screenSelectDialog.o O.linux-x86_64/obj/QELabel.o O.linux-x86_64/obj/QELabelManager.o O.linux-x86_64/obj/QEGenericEdit.o O.linux-x86_64/obj/QELineEdit.o O.linux-x86_64/obj/QELineEditManager.o O.linux-x86_64/obj/QENumericEdit.o O.linux-x86_64/obj/QENumericEditManager.o O.linux-x86_64/obj/QELink.o O.linux-x86_64/obj/QELinkManager.o O.linux-x86_64/obj/QELog.o O.linux-x86_64/obj/QELogManager.o O.linux-x86_64/obj/QELogin.o O.linux-x86_64/obj/QELoginManager.o O.linux-x86_64/obj/QNumericEdit.o O.linux-x86_64/obj/QNumericEditManager.o O.linux-x86_64/obj/QEPeriodic.o O.linux-x86_64/obj/QEPeriodicManager.o O.linux-x86_64/obj/QEPeriodicTaskMenuExtension.o O.linux-x86_64/obj/PeriodicSetupDialog.o O.linux-x86_64/obj/PeriodicElementSetupForm.o O.linux-x86_64/obj/PeriodicDialog.o O.linux-x86_64/obj/QEPlot.o O.linux-x86_64/obj/QEPlotManager.o O.linux-x86_64/obj/QEPlotter.o O.linux-x86_64/obj/QEPlotterItemDialog.o O.linux-x86_64/obj/QEPlotterMenu.o O.linux-x86_64/obj/QEPlotterState.o O!
.linux-x86_64/obj/QEPlotterToolBar.o O.linux-x86_64/obj/QEPlotterManage!
r.o O.linux-x86_64/obj/QEPvLoadSave.o O.linux-x86_64/obj/QEPvLoadSaveItem.o O.linux-x86_64/obj/QEPvLoadSaveModel.o O.linux-x86_64/obj/QEPvLoadSaveManager.o O.linux-x86_64/obj/QEPvLoadSaveUtilities.o O.linux-x86_64/obj/QEPvLoadSaveGroupNameDialog.o O.linux-x86_64/obj/QEPvLoadSaveValueEditDialog.o O.linux-x86_64/obj/QEPvProperties.o O.linux-x86_64/obj/QEPvPropertiesUtilities.o O.linux-x86_64/obj/QEPvPropertiesManager.o O.linux-x86_64/obj/QRadioGroup.o O.linux-x86_64/obj/QRadioGroupManager.o O.linux-x86_64/obj/QERadioGroup.o O.linux-x86_64/obj/QERadioGroupManager.o O.linux-x86_64/obj/QERecipe.o O.linux-x86_64/obj/QERecipeManager.o O.linux-x86_64/obj/QEResizeableFrame.o O.linux-x86_64/obj/QEResizeableFrameManager.o O.linux-x86_64/obj/QEScratchPad.o O.linux-x86_64/obj/QEScratchPadMenu.o O.linux-x86_64/obj/QEScratchPadManager.o O.linux-x86_64/obj/QEScript.o O.linux-x86_64/obj/QEScriptManager.o O.linux-x86_64/obj/QEShape.o O.linux-x86_64/obj/QEShapeManager.o O.linux-x86_64/obj/QSi!
mpleShape.o O.linux-x86_64/obj/QSimpleShapeManager.o O.linux-x86_64/obj/QESimpleShape.o O.linux-x86_64/obj/QESimpleShapeManager.o O.linux-x86_64/obj/QESlider.o O.linux-x86_64/obj/QESliderManager.o O.linux-x86_64/obj/QESpinBox.o O.linux-x86_64/obj/QESpinBoxManager.o O.linux-x86_64/obj/QEStripChart.o O.linux-x86_64/obj/QEStripChartState.o O.linux-x86_64/obj/QEStripChartAdjustPVDialog.o O.linux-x86_64/obj/QEStripChartContextMenu.o O.linux-x86_64/obj/QEStripChartDurationDialog.o O.linux-x86_64/obj/QEStripChartItem.o O.linux-x86_64/obj/QEStripChartRangeDialog.o O.linux-x86_64/obj/QEStripChartTimeDialog.o O.linux-x86_64/obj/QEStripChartToolBar.o O.linux-x86_64/obj/QEStripChartUtilities.o O.linux-x86_64/obj/QEStripChartManager.o O.linux-x86_64/obj/QEStripChartStatistics.o O.linux-x86_64/obj/QESubstitutedLabel.o O.linux-x86_64/obj/QESubstitutedLabelManager.o O.linux-x86_64/obj/QETable.o O.linux-x86_64/obj/QETableManager.o O.linux-x86_64/obj/moc_QEAxisPainter.o O.linux-x86_64/obj/mo!
c_QEDialog.o O.linux-x86_64/obj/moc_QEDelayedText.o O.linux-x86_64/obj/!
moc_QEFileMonitor.o O.linux-x86_64/obj/moc_QEFixedPointRadix.o O.linux-x86_64/obj/moc_QEPVNameSelectDialog.o O.linux-x86_64/obj/moc_QEGraphic.o O.linux-x86_64/obj/moc_QEScanTimers.o O.linux-x86_64/obj/moc_PasswordDialog.o O.linux-x86_64/obj/moc_windowCustomisation.o O.linux-x86_64/obj/moc_QCaEventFilter.o O.linux-x86_64/obj/moc_QCaObject.o O.linux-x86_64/obj/moc_QCaVariableNamePropertyManager.o O.linux-x86_64/obj/moc_QEByteArray.o O.linux-x86_64/obj/moc_QEFloating.o O.linux-x86_64/obj/moc_QEInteger.o O.linux-x86_64/obj/moc_QEString.o O.linux-x86_64/obj/moc_qepicspv.o O.linux-x86_64/obj/moc_maiaFault.o O.linux-x86_64/obj/moc_maiaObject.o O.linux-x86_64/obj/moc_maiaXmlRpcClient.o O.linux-x86_64/obj/moc_QEArchiveInterface.o O.linux-x86_64/obj/moc_QEArchiveManager.o O.linux-x86_64/obj/moc_QEArchiveStatus.o O.linux-x86_64/obj/moc_QEArchiveStatusManager.o O.linux-x86_64/obj/moc_QEArchiveNameSearch.o O.linux-x86_64/obj/moc_QEArchiveNameSearchManager.o O.linux-x86_64/obj/moc_UserMe!
ssage.o O.linux-x86_64/obj/moc_contextMenu.o O.linux-x86_64/obj/moc_QEWidget.o O.linux-x86_64/obj/moc_QEDesignerPlugin.o O.linux-x86_64/obj/moc_ContainerProfile.o O.linux-x86_64/obj/moc_persistanceManager.o O.linux-x86_64/obj/moc_applicationLauncher.o O.linux-x86_64/obj/moc_QEAbstractWidget.o O.linux-x86_64/obj/moc_QEAnalogIndicator.o O.linux-x86_64/obj/moc_QEAnalogIndicatorManager.o O.linux-x86_64/obj/moc_QEAnalogProgressBar.o O.linux-x86_64/obj/moc_QEAnalogProgressBarManager.o O.linux-x86_64/obj/moc_QBitStatus.o O.linux-x86_64/obj/moc_QBitStatusManager.o O.linux-x86_64/obj/moc_QEBitStatus.o O.linux-x86_64/obj/moc_QEBitStatusManager.o O.linux-x86_64/obj/moc_QEPushButton.o O.linux-x86_64/obj/moc_QERadioButton.o O.linux-x86_64/obj/moc_QECheckBox.o O.linux-x86_64/obj/moc_QEPushButtonManager.o O.linux-x86_64/obj/moc_QERadioButtonManager.o O.linux-x86_64/obj/moc_QECheckBoxManager.o O.linux-x86_64/obj/moc_QEComboBox.o O.linux-x86_64/obj/moc_QEComboBoxManager.o O.linux-x86_64/obj!
/moc_QEConfiguredLayout.o O.linux-x86_64/obj/moc_QEConfiguredLayoutMana!
ger.o O.linux-x86_64/obj/moc_QEFileBrowser.o O.linux-x86_64/obj/moc_QEFileBrowserManager.o O.linux-x86_64/obj/moc_QEFileImage.o O.linux-x86_64/obj/moc_QEFileImageManager.o O.linux-x86_64/obj/moc_QEForm.o O.linux-x86_64/obj/moc_QEFormManager.o O.linux-x86_64/obj/moc_QEFormGrid.o O.linux-x86_64/obj/moc_QEFormGridManager.o O.linux-x86_64/obj/moc_QEFrame.o O.linux-x86_64/obj/moc_QEFrameManager.o O.linux-x86_64/obj/moc_QEGeneralEdit.o O.linux-x86_64/obj/moc_QEGeneralEditManager.o O.linux-x86_64/obj/moc_QEGroupBox.o O.linux-x86_64/obj/moc_QEGroupBoxManager.o O.linux-x86_64/obj/moc_QEHistogram.o O.linux-x86_64/obj/moc_QEHistogramManager.o O.linux-x86_64/obj/moc_QEScalarHistogram.o O.linux-x86_64/obj/moc_QEScalarHistogramManager.o O.linux-x86_64/obj/moc_QEWaveformHistogram.o O.linux-x86_64/obj/moc_QEWaveformHistogramManager.o O.linux-x86_64/obj/moc_imageContextMenu.o O.linux-x86_64/obj/moc_flipRotateMenu.o O.linux-x86_64/obj/moc_profilePlot.o O.linux-x86_64/obj/moc_QEImage.o O.linu!
x-x86_64/obj/moc_QEImageManager.o O.linux-x86_64/obj/moc_selectMenu.o O.linux-x86_64/obj/moc_videowidget.o O.linux-x86_64/obj/moc_zoomMenu.o O.linux-x86_64/obj/moc_brightnessContrast.o O.linux-x86_64/obj/moc_QEImageOptionsDialog.o O.linux-x86_64/obj/moc_QEImageMarkupThickness.o O.linux-x86_64/obj/moc_fullScreenWindow.o O.linux-x86_64/obj/moc_markupDisplayMenu.o O.linux-x86_64/obj/moc_recording.o O.linux-x86_64/obj/moc_screenSelectDialog.o O.linux-x86_64/obj/moc_QELabel.o O.linux-x86_64/obj/moc_QELabelManager.o O.linux-x86_64/obj/moc_QEGenericEdit.o O.linux-x86_64/obj/moc_QELineEdit.o O.linux-x86_64/obj/moc_QELineEditManager.o O.linux-x86_64/obj/moc_QENumericEdit.o O.linux-x86_64/obj/moc_QENumericEditManager.o O.linux-x86_64/obj/moc_QELink.o O.linux-x86_64/obj/moc_QELinkManager.o O.linux-x86_64/obj/moc_QELog.o O.linux-x86_64/obj/moc_QELogManager.o O.linux-x86_64/obj/moc_QELogin.o O.linux-x86_64/obj/moc_QELoginManager.o O.linux-x86_64/obj/moc_QNumericEdit.o O.linux-x86_64/obj!
/moc_QNumericEditManager.o O.linux-x86_64/obj/moc_QEPeriodic.o O.linux-!
x86_64/obj/moc_QEPeriodicManager.o O.linux-x86_64/obj/moc_QEPeriodicTaskMenu.o O.linux-x86_64/obj/moc_PeriodicSetupDialog.o O.linux-x86_64/obj/moc_PeriodicElementSetupForm.o O.linux-x86_64/obj/moc_PeriodicDialog.o O.linux-x86_64/obj/moc_QEPlot.o O.linux-x86_64/obj/moc_QEPlotManager.o O.linux-x86_64/obj/moc_QEPlotter.o O.linux-x86_64/obj/moc_QEPlotterNames.o O.linux-x86_64/obj/moc_QEPlotterItemDialog.o O.linux-x86_64/obj/moc_QEPlotterMenu.o O.linux-x86_64/obj/moc_QEPlotterToolBar.o O.linux-x86_64/obj/moc_QEPlotterManager.o O.linux-x86_64/obj/moc_QEPvLoadSave.o O.linux-x86_64/obj/moc_QEPvLoadSaveCommon.o O.linux-x86_64/obj/moc_QEPvLoadSaveItem.o O.linux-x86_64/obj/moc_QEPvLoadSaveModel.o O.linux-x86_64/obj/moc_QEPvLoadSaveManager.o O.linux-x86_64/obj/moc_QEPvLoadSaveGroupNameDialog.o O.linux-x86_64/obj/moc_QEPvLoadSaveValueEditDialog.o O.linux-x86_64/obj/moc_QEPvProperties.o O.linux-x86_64/obj/moc_QEPvPropertiesManager.o O.linux-x86_64/obj/moc_QRadioGroup.o O.linux-x86_64/obj!
/moc_QRadioGroupManager.o O.linux-x86_64/obj/moc_QERadioGroup.o O.linux-x86_64/obj/moc_QERadioGroupManager.o O.linux-x86_64/obj/moc_QERecipe.o O.linux-x86_64/obj/moc_QERecipeManager.o O.linux-x86_64/obj/moc_QEResizeableFrame.o O.linux-x86_64/obj/moc_QEResizeableFrameManager.o O.linux-x86_64/obj/moc_QEScratchPad.o O.linux-x86_64/obj/moc_QEScratchPadMenu.o O.linux-x86_64/obj/moc_QEScratchPadManager.o O.linux-x86_64/obj/moc_QEScript.o O.linux-x86_64/obj/moc_QEScriptManager.o O.linux-x86_64/obj/moc_QEShape.o O.linux-x86_64/obj/moc_QEShapeManager.o O.linux-x86_64/obj/moc_QSimpleShape.o O.linux-x86_64/obj/moc_QSimpleShapeManager.o O.linux-x86_64/obj/moc_QESimpleShape.o O.linux-x86_64/obj/moc_QESimpleShapeManager.o O.linux-x86_64/obj/moc_QESlider.o O.linux-x86_64/obj/moc_QESliderManager.o O.linux-x86_64/obj/moc_QESpinBox.o O.linux-x86_64/obj/moc_QESpinBoxManager.o O.linux-x86_64/obj/moc_QEStripChart.o O.linux-x86_64/obj/moc_QEStripChartAdjustPVDialog.o O.linux-x86_64/obj/moc_QEStr!
ipChartContextMenu.o O.linux-x86_64/obj/moc_QEStripChartDurationDialog.!
o O.linux-x86_64/obj/moc_QEStripChartItem.o O.linux-x86_64/obj/moc_QEStripChartNames.o O.linux-x86_64/obj/moc_QEStripChartRangeDialog.o O.linux-x86_64/obj/moc_QEStripChartTimeDialog.o O.linux-x86_64/obj/moc_QEStripChartToolBar.o O.linux-x86_64/obj/moc_QEStripChartManager.o O.linux-x86_64/obj/moc_QEStripChartStatistics.o O.linux-x86_64/obj/moc_QESubstitutedLabel.o O.linux-x86_64/obj/moc_QESubstitutedLabelManager.o O.linux-x86_64/obj/moc_QETable.o O.linux-x86_64/obj/moc_QETableManager.o O.linux-x86_64/obj/qrc_common.o O.linux-x86_64/obj/qrc_archive.o O.linux-x86_64/obj/qrc_QEAnalogIndicator.o O.linux-x86_64/obj/qrc_QEAnalogProgressBar.o O.linux-x86_64/obj/qrc_QEBitStatus.o O.linux-x86_64/obj/qrc_QEButton.o O.linux-x86_64/obj/qrc_QEComboBox.o O.linux-x86_64/obj/qrc_QEConfiguredLayout.o O.linux-x86_64/obj/qrc_QEFileBrowser.o O.linux-x86_64/obj/qrc_QEFileImage.o O.linux-x86_64/obj/qrc_QEForm.o O.linux-x86_64/obj/qrc_QEFormGrid.o O.linux-x86_64/obj/qrc_QEFrame.o O.linux-x86_64/ob!
j/qrc_QEGeneralEdit.o O.linux-x86_64/obj/qrc_QEGroupBox.o O.linux-x86_64/obj/qrc_QEHistogram.o O.linux-x86_64/obj/qrc_QEImage.o O.linux-x86_64/obj/qrc_QELabel.o O.linux-x86_64/obj/qrc_QELineEdit.o O.linux-x86_64/obj/qrc_QELink.o O.linux-x86_64/obj/qrc_QELog.o O.linux-x86_64/obj/qrc_QELogin.o O.linux-x86_64/obj/qrc_QENumericEdit.o O.linux-x86_64/obj/qrc_QEPeriodic.o O.linux-x86_64/obj/qrc_QEPlot.o O.linux-x86_64/obj/qrc_QEPlotter.o O.linux-x86_64/obj/qrc_QEPvLoadSave.o O.linux-x86_64/obj/qrc_QEPvProperties.o O.linux-x86_64/obj/qrc_QERadioGroup.o O.linux-x86_64/obj/qrc_QERecipe.o O.linux-x86_64/obj/qrc_QEResizeableFrame.o O.linux-x86_64/obj/qrc_QEScratchPad.o O.linux-x86_64/obj/qrc_QEScript.o O.linux-x86_64/obj/qrc_QEShape.o O.linux-x86_64/obj/qrc_QESimpleShape.o O.linux-x86_64/obj/qrc_QESlider.o O.linux-x86_64/obj/qrc_QESpinBox.o O.linux-x86_64/obj/qrc_QEStripChart.o O.linux-x86_64/obj/qrc_QESubstitutedLabel.o O.linux-x86_64/obj/qrc_QETable.o -L/nfs/opt/qt-4.8.5/lib -L/nfs!
/erl/erp/epics/R3.14.12/support/base-3.14.12.2/lib/linux-x86_64 -lca -l!
Com -lqwt -lQtScript -L/nfs/opt/qt-4.8.5/lib -L/usr/X11R6/lib -lQtNetwork -lQtDesigner -lQtUiTools -L/tmp/qt4/qt-everywhere-opensource-src-4.8.5/lib -lQtXml -lQtGui -lQtCore -lpthread
/usr/bin/ld: cannot find -lqwt
Sent: Friday, April 17, 2015 3:58 PM
To: John Dobbins; [email protected]
Subject: RE: epicsQt and QWT6
From: [email protected] [[email protected]] on behalf of John Dobbins [[email protected]]
Sent: Friday, April 17, 2015 12:48 PM
To: [email protected]
Subject: epicsQt and QWT6
All,
I am taking my first look at epicsQt and caQtDM. I built epicsQt with Qt-4.8.5 and Qwt-5.2.3. All peace and happiness. Then I looked at caQtDM and see that the latest version, 3.9.1, is calling for Qwt 6.0.1
I built qwt 6.0.1 but haven't been able to build epicsQt against it. For reasons I don't understand it won't find the qwt lib.
So I'm just wondering if any knows that this (epicsQt with Qwt 6) should work before I bang my head some more.
Yes, indeed it does work.
What version of peicsQt are you using?
Please, show the error message that you get.
Cheers,
Ernest
John Dobbins
Cornell University Laboratory for Accelerator-Based Sciences and Education
- epicsQt and QWT6 John Dobbins
- RE: epicsQt and QWT6 Williams Jr., Ernest L.
- Re: epicsQt and QWT6 John Dobbins
macro value l123173
EPICS installed, making ioc, not working... Chris Eckman
<2015>
2025
2026
Re: epicsQt and QWT6 Zenon Szalata
<2015>
2025
2026
