Hi Jorn,
I assume you tried ea4-cpp on hithub. This is an intermediate version implemented with EPICS V 4.3
I expect to formally release it by the EPICS meeting, May 18-22.
Since you triggered this topic, I would like to add some advertisement for this project.
In short, the EPICS V4 Archiver Service (ea4) is designed after the Spark programming model
and MongoDB API and extends them for hybrid systems (including control time series and
experimental results). Currently, the service is implemented around the original Channel
Archiver IO library deployed on the V4 middle layer. For example, it can be illustrated by
the following scripts:
http://nbviewer.ipython.org/github/malitsky/eapy/blob/master/examples/TimeSeries.ipynb
http://nbviewer.ipython.org/github/malitsky/eapy/blob/master/examples/Snapshot.ipynb
The programming model (together V4 middle layer) however opens the door for multiple extensions,
such as (in-memory) map-reduce data processing, etc.
The initial formal release will include:
1. EPICS V 4.4
2. MongoDB examples
3. Demo
4. Web site, API, etc.
Nikolay Malitsky
From: [email protected] [[email protected]] on behalf of Jörn Wüstenfeld [[email protected]]
Sent: Monday, April 20, 2015 1:45 AM
To: [email protected]
Subject: ChannelArchiver and EPICS4
Hello,
I'm trying to compile the latest version of the epichchannelarchiver together
with EPICS4 versionn 4.4.0. But I run into problems:
epicschanarch-ea4-cpp/src/common/pva/ArchiveChannelProviderFactory.cpp: In
construktor
»ea4::pva::ArchiveChannelProviderFactory::ArchiveChannelProviderFactory()«:
epicschanarch-ea4-cpp/src/common/pva/ArchiveChannelProviderFactory.cpp:11:41:
Error: an abtract object of type »ea4::pva::ArchiveChannelProvider« can not be
instantiated
m_provider(new ArchiveChannelProvider()){
Are these versions compatible, or do I need to use EPICS 4.3.0?
Regards
Jörn Wüstenfeld
- RE: ChannelArchiver and EPICS4 Malitsky, Nikolay D
- ChannelArchiver and EPICS4 Jörn Wüstenfeld
Re: EPICS installed, making ioc, not working... Konrad, Martin
RE: EPICS installed, making ioc, not working... Mooney, Tim M.
<2015>
2025
2026
<2015>
2025
2026
